Home > Technical (L322) > CV boot and Suspension arm pin |
l322novice Member Since: 15 Jan 2016 Location: South Posts: 30 |
Good morning and Season's Greetings to you all.
29th Dec 2018 4:52am |
Thanks bembo449, it's the front inner that needs replacing. |
29th Dec 2018 6:22pm |
Happy Eater Member Since: 05 Dec 2017 Location: Maidstone Posts: 7 |
Have you ever done an inner drive shaft CV joint gaiter on any car?
29th Dec 2018 8:17pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
I’ve changed the outer cv joints and it wasn’t fun although you won’t need to remove the outer joint and you can remove the inner one with the whole driveshaft removed. You need the correct socket to remove the hub nut, ideally a new nut, there is a special tool to push and pull the shaft though the hub but I managed without it , you need to be able to split the ball joints without splitting the rubbers which is another special tool ideally , a torque wrench that goes up to over 400 Nm if I recall correctly , new diff seal and I think oil for the diff, the boot of course and ideally the cv retainer clip pliers or old style pincers, think that’s about it. Rave lists another tool to remove the inner cv joint from the diff but you could probably use a couple of levers.
31st Dec 2018 1:03am |
