Home > Technical (L322) > Heeeeeeelp !
Page 1 of 3 123>
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
Heeeeeeelp !
Got my suspension stuck on the lowest height! Im using a snap on solus and was recalibrating the ride height , ive now somehow got it stuck , wished id not touched it Big Cry
Post #499874 28th Dec 2018 1:38pm
ptaroni
Give the pump a bit of time to cool down then check/clear codes and try again! 2004 td6 l322 - gone
Now 2007 tdv8 l322
Post #499883 28th Dec 2018 3:04pm
bembo449
Ok pal , ive parked it up , not guna av time to try again
Post #499886 28th Dec 2018 3:53pm
Or youve lowered it past the hight sensor perameters so would need to physically jack the car up for it to see the sensors... Neutral
Post #499896 28th Dec 2018 5:17pm
ptaroni
Would have thought that the sensor would still read on the bump stops though, as that would be the lowest it could possibly go?? I am going to attempt this on my snapon machine at some point so would be good to know either way 2004 td6 l322 - gone
Now 2007 tdv8 l322
Post #499897 28th Dec 2018 5:22pm
Paul thornton
I had no issues with my 05 model.
Lowered the access and running heights individually and they stayed like that for 18 months before I reverted it back to standard and sold the car.
Only issue was that the ride was considerably firmer and that was with only a 15mm drop. Cornered and looked miles better though.
I used an IID tool.
Post #499898 28th Dec 2018 5:47pm
holidaychicken
Don’t know about the snap on kit but the RSW Allcomms has a specific program for setting the EAS heights.
Post #499909 28th Dec 2018 6:58pm
bembo449
If its a snap on solus it will only have calibration bit thats what i used and look what happened Shocked
Post #499911 28th Dec 2018 7:44pm
holidaychicken
I am guessing English is not your first language ?
Post #499942 29th Dec 2018 1:34am
bembo449
sorry , I thought I'd done a quote reply ! was in a rush to get to the pub Razz
Post #499946 29th Dec 2018 6:10am
bembo449
I don't mind buying a tool aslong as it will defo sort the suspension side of the FF but buying iiD just for doing that is a bit much Neutral
Post #499947 29th Dec 2018 6:14am
ptaroni
Well had a go at mine using snapon modis edge and what a massive pain!! Gave up in the end. Then realised that i have different wheels on than standard so that will mess up the height between centre of hub to wheel arch! The iidtool was so so much more simple!
It raised then lowered everytime and even on a new compressor it had to cool before it would continue 2004 td6 l322 - gone
Now 2007 tdv8 l322
Post #500005 29th Dec 2018 3:49pm
holidaychicken
The RSW Allcoms has a specific program for the suspension calibration and is not locked to a VIN so if you can borrow one you might have a chance.
One of the warnings it does give before using it is that the suspension should not have any faults but by the sound of it you don't have much to lose.
I don't know if any of the Icarsoft tools can calibrate the suspension as they are probably the cheapest diagnostic tools you can buy that actually do something more than just read faults.
Post #500079 30th Dec 2018 12:22pm
bembo449
bit of an update , rangeys been left till this morning as I just haven't had the time spare to work on it , I borrowed a snap on Modus as I was told it had more functions on than the Solus but its exactly the same for Landrover , so I tried Bmw E53 X5 and it accesses the suspension just fine , now ive managed to get the car level but only at the low setting , I tested individual raise / lower function and all worked well but I still cannot get the car to stay at the normal road height , the front just sinks back down once I start moving
is there a specific order or method I need to use to get a response from the toggle ?? any help / hints will be very helpfull
thanks
simon
Post #501828 16th Jan 2019 7:40pm
holidaychicken
Does it help if you press the toggle button in which is the inhibit movement witch, worth a try?
Have you got any lights on the the switch or next to it indicating the height?
When i have had suspension locked out i have had to go in and use allcomms or faultmate to clear the fault and bring the system back to life
Post #501834 16th Jan 2019 8:18pm
Page 1 of 3 123>
