Home > Technical (L322) > Heeeeeeelp ! |
ptaroni Member Since: 20 Dec 2015 Location: leicestershire Posts: 89 |
Give the pump a bit of time to cool down then check/clear codes and try again! 2004 td6 l322 - gone
28th Dec 2018 3:04pm |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 |
Ok pal , ive parked it up , not guna av time to try again |
28th Dec 2018 3:53pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16280 |
Or youve lowered it past the hight sensor perameters so would need to physically jack the car up for it to see the sensors... |
28th Dec 2018 5:17pm |
Would have thought that the sensor would still read on the bump stops though, as that would be the lowest it could possibly go?? I am going to attempt this on my snapon machine at some point so would be good to know either way 2004 td6 l322 - gone
28th Dec 2018 5:22pm |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 |
I had no issues with my 05 model.
28th Dec 2018 5:47pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
Don’t know about the snap on kit but the RSW Allcomms has a specific program for setting the EAS heights. |
28th Dec 2018 6:58pm |
If its a snap on solus it will only have calibration bit thats what i used and look what happened |
28th Dec 2018 7:44pm |
I am guessing English is not your first language ? |
29th Dec 2018 1:34am |
sorry , I thought I'd done a quote reply ! was in a rush to get to the pub |
29th Dec 2018 6:10am |
I don't mind buying a tool aslong as it will defo sort the suspension side of the FF but buying iiD just for doing that is a bit much |
29th Dec 2018 6:14am |
Well had a go at mine using snapon modis edge and what a massive pain!! Gave up in the end. Then realised that i have different wheels on than standard so that will mess up the height between centre of hub to wheel arch! The iidtool was so so much more simple!
29th Dec 2018 3:49pm |
The RSW Allcoms has a specific program for the suspension calibration and is not locked to a VIN so if you can borrow one you might have a chance.
30th Dec 2018 12:22pm |
bit of an update , rangeys been left till this morning as I just haven't had the time spare to work on it , I borrowed a snap on Modus as I was told it had more functions on than the Solus but its exactly the same for Landrover , so I tried Bmw E53 X5 and it accesses the suspension just fine , now ive managed to get the car level but only at the low setting , I tested individual raise / lower function and all worked well but I still cannot get the car to stay at the normal road height , the front just sinks back down once I start moving
16th Jan 2019 7:40pm |
Does it help if you press the toggle button in which is the inhibit movement witch, worth a try?
16th Jan 2019 8:18pm |
