![]() | Home > Technical (L322) > L322 '02 Fuse #12 Blowing when A/C or A/C Max pressed |
ptaroni Member Since: 20 Dec 2015 Location: leicestershire Posts: 89 ![]() ![]() ![]() |
Disconnect ac compressor plug.. replace the fuse then press ac button, if it blows then you have a short somewhere but if it doesnt then your ac compressor has had it! 2004 td6 l322 - gone
rachob Member Since: 16 Dec 2018 Location: GEELONG Posts: 3 ![]() ![]() ![]() |
Hi ptaroni thanks for the reply. Is the plug you are referring to the multi plug which connects to the compressor?
Hi sorry for late reply, yes the connector on the aircon compressor! Not sure on how easy it is to access though! 2004 td6 l322 - gone
Well ptaroni you were spot on. Managed to access the plug to the a/c compressor (not the one that connects directly to the compressor as this is near on impossible to access it without removing the intercooler hose) but the connector at the other at the other end which is conveniently located near the a/c pipes.
No problem! Nice to be able to give some back after getting so much useful information on here! 2004 td6 l322 - gone
