![]() | Home > Technical (L322) > 2008 TDV8 Suspension fault - 30mph max msg FIXED |
elandri Member Since: 28 Apr 2015 Location: Norwich Posts: 43 ![]() ![]() ![]() |
I've had the car 3.5 years, 30K miles - never had a peep from the suspension. Has 110K on the clock.
Thanks for input but it had a new alternator a couple of years back and the charging was checked before the new battery fitted last week so I don't think it's that. 2008 TDV8 Vogue |
tony66 Member Since: 30 Nov 2014 Location: fife Posts: 92 ![]() ![]() ![]() |
check battery is good-even if new,i have had a duff new one before[non rangie] |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 521 ![]() ![]() ![]() |
Use the IID to monitor live values on the suspension heights as you drive along. The 4x4 screen does suggest you might have a dodgy sensor / wire. 2016 Skoda Octavia VRS Estate
ptaroni Member Since: 20 Dec 2015 Location: leicestershire Posts: 89 ![]() ![]() ![]() |
Or a leak on that side... mine did this when the osf airbag split just after buying it.. bong then it went down to the bump stops , was no fun at all when to are on the motorway! Pulled into the next service station to allow the compressor to cool down enough for a few more miles of comfort.
MikeO - thanks - the live values confirm something fishy with the left rear suspension height - readings are all over the place!
In the course of replacing the ride height sensor one of the wires to the plug broke off. A bit of googling revealed that there is a very widely available repair kit available so it seems that this is a common occurrence.
excellent-good when its a cheap fix |
