![]() | Home > Maintenance & Mods (L322) > headlight dipped beam keeps flickering then going out? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35465 ![]() ![]() |
change bulbs over from near side to the dodgy light , if that bulb dont work it could be the ballast on the way out.. ... - .- -.
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
Maybe...
nick h Member Since: 26 Jan 2011 Location: notts Posts: 782 ![]() ![]() |
thanks fortunately my jeep mechanic is on his way over to pick up my fathers car for a service so he's going to have a look IF its the ballast - is it going to cost an arm and leg to replace/install? i can't really afford to sell any more organs ![]() |
Search "ballast", quite a few posts on this. |
my mechanic has just been - yes its the ballast
further checking by my mechanic this morning actually showed it to be a bulb 'on the way out' - not ballast as first thought
did you not change the bulbs over like i suggested nick, tut tut..... |
i left it all in the hands of my mechanic ![]() i was perhaps presumptuous when i initially said it was the ballast? i got the OEM bulbs because they were such a good price compared with what main stealers charge ![]() even andrew page wanted £53 + VAT each for non OEM also they were available to be collected/fitted this morning what was very noticeable was side by side how much brighter a new bulb was compared with the existing one |
i have read that hid bulbs do indeed loose their brightness after a while and they go pinky colour shortly before they fail...how much did you pay and where did you get the bulbs from nick... ... - .- -.
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1747 ![]() ![]() ![]() |
Interesting post Nick - On my way home this evening (after a very boring film at the flicks) I noticed my drivers side headlight flicker and then went out - Just left with side light. I turned them off and on again at some T LIghts and it came back on. It did it again just as I turned into my drive.
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 ![]() ![]() |
My drivers side light flickered then went off when I first bought my car a year back, it did it 4 or 5 times in a row, but then came back on and has been fine since. Could it be a loose connection somewhere? 2006 Mercedes CLS
Is there a special process to remove the bulbs to swap them over. I read somewhere not to play with these as they can push out 25,000 volts or something.
no special way , just make sure they aren't switched on when you change them. |
