Home > Maintenance & Mods (L322) > headlight dipped beam keeps flickering then going out?
nick h
2005 Range Rover Vogue 4.4 V8 Tonga Green
my neighbour told me this morning that my offside dipped headlight was not working
turned the lights on again and after about 5 seconds it started to flicker and went out - then came back on and went out and stayed out
loose connector?
btw it was in auto sensing mode
all suggestions welcome
thanks in anticipation
Post #49457 9th Feb 2011 12:12pm
change bulbs over from near side to the dodgy light , if that bulb dont work it could be the ballast on the way out.. ... - .- -.
Post #49458 9th Feb 2011 12:16pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
Maybe...
http://cgi.ebay.co.uk/Range-Rover-Head-Lam...25610c6dd6 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #49459 9th Feb 2011 12:17pm
nick h
thanks
fortunately my jeep mechanic is on his way over to pick up my fathers car for a service so he's going to have a look
IF its the ballast - is it going to cost an arm and leg to replace/install?
i can't really afford to sell any more organs Rolling with laughter
Post #49460 9th Feb 2011 12:19pm
elpeede
Search "ballast", quite a few posts on this. Thumbs Up 2010 Disco XS TDV6, 2009 Freelander 2 GS
Post #49461 9th Feb 2011 12:23pm
nick h
my mechanic has just been - yes its the ballast
but he knows a source for a replacement at the right price
thanks guys for all your help
Post #49474 9th Feb 2011 1:50pm
nick h
further checking by my mechanic this morning actually showed it to be a bulb 'on the way out' - not ballast as first thought
anyway, pair of OEM bulbs sorted at the 'right price' - all fitted Very Happy
Post #49833 12th Feb 2011 11:26am
did you not change the bulbs over like i suggested nick, tut tut..... Very Happy Wink ...seriously , thats a good result..you should have gone for 6000k bulbs which give a whiter light with a blue ting rather than the OE yellowy bulbs.. ... - .- -.
Post #49835 12th Feb 2011 11:33am
nick h
i left it all in the hands of my mechanic Very Happy - and yes he did the bulb swap which identified the problem!
i was perhaps presumptuous when i initially said it was the ballast?
i got the OEM bulbs because they were such a good price compared with what main stealers charge Smile
even andrew page wanted £53 + VAT each for non OEM
also they were available to be collected/fitted this morning
what was very noticeable was side by side how much brighter a new bulb was compared with the existing one
Post #49839 12th Feb 2011 12:46pm
i have read that hid bulbs do indeed loose their brightness after a while and they go pinky colour shortly before they fail...how much did you pay and where did you get the bulbs from nick... ... - .- -.
Post #49870 12th Feb 2011 5:08pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Interesting post Nick - On my way home this evening (after a very boring film at the flicks) I noticed my drivers side headlight flicker and then went out - Just left with side light. I turned them off and on again at some T LIghts and it came back on. It did it again just as I turned into my drive.
Is it more likely to be the bulb or the ballast - Will try the bulb swap but it seems to be intermittent right now.
May I ask Nick which bulbs you got and how much they were..? Do you have a good source for them.
Can I also assume that if its the ballast it's mega bucks? Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #49956 12th Feb 2011 11:19pm
M44K TS
My drivers side light flickered then went off when I first bought my car a year back, it did it 4 or 5 times in a row, but then came back on and has been fine since. Could it be a loose connection somewhere? 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #49959 12th Feb 2011 11:29pm
comports
Is there a special process to remove the bulbs to swap them over. I read somewhere not to play with these as they can push out 25,000 volts or something.
My drivers side still flickers sometimes and goes put so want to first swap bulbs to see if it's bulb or ballast. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #53581 8th Mar 2011 9:05pm
no special way , just make sure they aren't switched on when you change them. Very Happy
i make sure that the range has been standing for at least 20 minutes before doing any thing to the ranges electrics so that any ecu's etc have time to power down ...
btw,dont touch the filaments. ... - .- -.
Post #53584 8th Mar 2011 9:16pm
