Home > Maintenance & Mods (L322) > How do I remove the rear black plastic pillar cover?
Danwilderspin
I want to hide a dab antenna under here how do I remove?
Cheers
 Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #498392 13th Dec 2018 8:03am
I seem to recall it's held on by 3 bolts accessible from behind the internal trim.
Post #498395 13th Dec 2018 9:24am
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
There are three 'scrivet' type fixings accessible with the upper tailgate open, you need to press or pull out the centre plastic pin and the fixings then come out, the trim is also secured with trim clips (similar to door card fixings) so just a case of a firm tug to pull it away from the pillar.
You may want to buy new fixings before removing as some tend to break no matter how careful you are!
Post #498407 13th Dec 2018 11:16am
