![]() | Home > Maintenance & Mods (L322) > How do I remove the rear black plastic pillar cover? |
I seem to recall it's held on by 3 bolts accessible from behind the internal trim. |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 895 ![]() ![]() ![]() |
There are three 'scrivet' type fixings accessible with the upper tailgate open, you need to press or pull out the centre plastic pin and the fixings then come out, the trim is also secured with trim clips (similar to door card fixings) so just a case of a firm tug to pull it away from the pillar.
