Home > Technical (L405) > L405 tailgate height when open
jumpin mouse
United Kingdom 2015 Range Rover Autobiography SDV8 Aruba
I'm hoping that this issue might have been experienced by someone here that can help me to understand what is happening.
I had the vehicle for over a year before I noticed an issue, when I bashed the top of my head on the sharp corner of the tailgate. I then found that I could manually lift the tailgate about 3 or 4 inches higher which would give me ample clearance for my bonce (5' 10"). I went through the height reset mode but it made no difference. The dealer and I compared this with a similar vehicle, also in access mode, and confirmed that this was not correct. New tailgate struts were fitted under warranty, this made no difference. I took the car back and they said that yes, this was still not right so they fitted the next set of tailgate struts and this also made no difference. The car is now booked into their bodyshop for diagnosis with the tailgate hinges being suspected. The car is immaculate, has never been off-road or mishandled and I am baffled.
Any ideas?
Post #498057 9th Dec 2018 11:13pm
jumpin mouse
No ideas anyone? Even wild suggestions would be appreciated at this stage, within reason Very Happy .
Post #498142 10th Dec 2018 8:40pm
Chalky
It's got to be something to do with the variable height which you can set I would have thought.
Not had any experience of setting the height though, but I know it can be done on my MY18 car. All LR cars from 1984
2021.5 Vogue SE D300 Carpathian Grey
2018 Vogue SE British Racing Green GONE
Post #498146 10th Dec 2018 9:17pm
have you set the tailgate opening height ?
info is in the manual..
Post #498147 10th Dec 2018 9:18pm
jumpin mouse
I have Stan and Chalky, that's what I was meaning by the: "I went through the height reset mode but it made no difference." I was quite excited when I read that in the manual but it made almost no difference. You lift the tailgate fully up, hold it there whilst you press the open/close button until it beeps, let go and the Censored drops again.
A hard-hat is one solution but there must be a technical answer to this.
Post #498226 11th Dec 2018 6:33pm
Bill
Re: L405 tailgate height when open
Any ideas?
I’m 6’2” and can re-confirm those corners are sharp.... & hurt!!!! a piece of triangular rubber would be ideal, if anyone has any ideas, I’ll buy a pair... Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
He who dies with the most toys wins...
Post #498232 11th Dec 2018 7:16pm
Chalky
The tailgate on a D5 is far worse. Both hurt though!! Big Cry All LR cars from 1984
Post #498239 11th Dec 2018 8:10pm
Fleagle_UK
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
probably of no help - but mine never opens to full height either - always an inch or 2 short. I've just put it down to manufacturing tolerances Shocked
Post #498311 12th Dec 2018 3:28pm
jumpin mouse
Could someone else please check this and tell me if, with the tailgate fully open, they are able to lift it a further few 2 or 3 inches and when the vehicle is in access mode can a 5' 10" person stand under the corner without whacking their head.
I'd really appreciate if anyone reading this could quickly check this so that I know if I should be chasing this issue.
Post #498364 12th Dec 2018 9:58pm
Emperor Mong
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Loire Blue
Be careful - it is very, very sharp. I saw a very nasty injury happen:
Emperor Mong wrote:
I have twice caught my head on the sharp corner of the upper tailgate.
Once was when I had it on the lowest suspension setting and walked round with eyes down looking for something in the boot. The second time, my daughter had pressed the electric close button and I was in the wrong place, looking the wrong way.
I'm 6'0". Taller would be more vulnerable.
Then I was shooting at the weekend. Another of the guns (not me) was bending to get something out of the boot of another L405. The owner (not me) had pressed the close button. Result was a collision of head with the sharp corner.
Cue a 3 inch gash and lots (and lot and lots) of blood. One of the chaps was a surgeon. The shoot had some sterile veterinary staples (dogs, for the use of). The gun was unwilling to go to A&E and miss his shooting so this was the outcome:
http://www.fullfatrr.com/forum/topic29085.html
As for how to get it to open to its full extent, if the reset isn't working, I'm at a loss.
Post #498380 12th Dec 2018 11:12pm
