Home > Technical (L322) > Just failed MOT for white rear position lights?
Flyingfocrs
Scotland 2014 Range Rover Autobiography SDV8 Santorini Black
So first MOT under the new rules and two majors
Nearside Rear Position lamp showing white light to the rear (4.2.3 (a) (ii))
Offside Rear Position lamp showing white light to the rear (4.2.3 (a) (ii))
Bit baffled as there aren’t any white bulbs in the back apart from the reverse ones.
Not had chance to speak to the tester yet or have a look at the car to contest it, but not even sure the car has rear position lights. (Quick edit:- appears rear position lights are what the rest of us call the rear or tail lights )
Vehicle has Powerful uK supercharged rear lights fitted but they weren’t a problem last year.
Anyone else had this issue?
Post #497879 7th Dec 2018 8:56pm
all SC up to 2010 had the white/clear lens with a clear bulb that when switched on would be orange/amber ..
the lights are item 3 in this pic,
the silver topped bulb should be like his,
i cant imagine why the tester had failed them
Post #497882 7th Dec 2018 9:32pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
Maybe the coating is failing and showing white light. Couple of new bulbs will sort it 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #497883 7th Dec 2018 9:46pm
As above... I reckon the colour coating has failed... Thumbs Up
Post #497889 7th Dec 2018 11:05pm
Flyingfocrs
It is set 3 that i have fitted.
Can’t remember if it was red covered bulbs i fitted but last time i looked they were illuminating red as the wife drove away.
Will speak to the tester in the morning and see what is going on exactly.
Post #497890 7th Dec 2018 11:06pm
The red bulbs are (forgive me being blunt sir) cheap and nasty... The coating peels off after a time... The irradium coated bulbs (blueish silver in colour) last loads longer... Thumbs Up
Have a look tomorrow, it only takes one chip out of the coating to deem them a failure sir... Rolling Eyes
Post #497893 7th Dec 2018 11:17pm
