Home > Technical (L322) > Heated rear screen help needed.......
Ianmaney
United Kingdom 2011 Range Rover Vogue SE TDV8 Mariana Black
I have a 2011 4.4 TDV8 and the rear heated screen doesn’t work, ive pulled fuse 15 and its fine, next things are to change the relay then change the glass, there are 3 lines on the screen that have come away, so would this cause the screen to die? And finally, can anyone tell me where the relay is please ? Semper in merda sumus, solum altum variat !!
Current: 2011 4.4 TDV8 Vogue SE
Last one: 2003 3.0 TD6 Vogue
Post #497308 2nd Dec 2018 12:01pm
if there is a break in the lines then the continuity is broken and the screen wont work..
Post #497309 2nd Dec 2018 12:04pm
Ianmaney
Thanks Stan 👍 Semper in merda sumus, solum altum variat !!
Post #497310 2nd Dec 2018 12:05pm
Paul thornton
Mine had a broken earth wire inside the tailgate. Was really obvious once I'd took the plastic panel off.
Post #497313 2nd Dec 2018 12:34pm
L322 Newbie
United Kingdom 2007 Range Rover Autobiography Black TDV8 Santorini Black
Hi
I used one of the proprietary silver line repair kits, this worked on mine- it may save you a complete replacement screen. Steve
2007 L322 RR Autobiography Black
1999 X100 Jaguar XKR Black
2008 Smart 451
Post #497760 6th Dec 2018 1:34pm
Swipe
United Kingdom 2004 Range Rover Autobiography Td6 Java Black
Just bought the screen repair for my vogue hope to get round to doing this fix soon. I seem to have quite a free breaks in the lines, how long does this take to repair?
Post #497767 6th Dec 2018 3:22pm
L322 Newbie
Hi
After cleaning the screen and applying the tape -silver coatign, took a couple of hours - I found it better to get into the boot area rather than work upside down. Steve
2008 Smart 451
Post #497784 6th Dec 2018 5:41pm
Swipe
Thanks was thinking it could take a couple of hours.
Thought the same about sitting in boot being easier.
Post #497786 6th Dec 2018 6:11pm
bishbosh10
If the screen itself is not the problem then I am advised that the relay is part of a fuse board and is not replaceable on its own. Still it is only £500+ for the fuse board...... Banging Head Banging Head Banging Head Banging Head Censored Censored Censored Censored Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #497862 7th Dec 2018 6:42pm
