![]() | Home > Maintenance & Mods (L322) > Towing electrics activation 2012 4.4 AB |
icarus76 Member Since: 07 Oct 2018 Location: Solihull Posts: 29 ![]() ![]() ![]() |
Hi There,
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35465 ![]() ![]() |
the iidtool is locked to the vehicle owners vin number.....there might be someone who has a 'pro' tool that can do this for you.. |
fingers crossed then |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1195 ![]() ![]() ![]() |
Otherwise, it`s £25 I think to get an additional car to the standard non-pro |
Certainly an option if someone were willing.
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2553 ![]() ![]() ![]() |
What needs activation? |
I believe it needs the ccf editing to tell it has a tow bar and 13 pin electrics to work fully. |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 ![]() ![]() ![]() |
In North Oxfordshire, just off M40 if that helps, it's not a pro though
wood78987 Member Since: 03 Mar 2016 Location: South Wales Posts: 135 ![]() ![]() ![]() |
If it helps, I fitted a westfalia towbar and electrics to my 2012 and didn't change anything with the IID tool.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8673 ![]() ![]() ![]() |
Rear parking sensors should be disabled when you plug in the trailer.
I'm a bit dubious of this trailer stability program and towing specific gearbox mapping. The car has no way of knowing through the trailer electrics if its a 2.5 tonne trailer or a towbar mounted bike rack that's fitted.
I haven't actually tried it as I haven't fitted the towbar yet - I was planning to do it today, but its too wet at the moment.. I'm going on what I have read on here - I believe that it will all work with the exception of disabling of park sensors and some fog light issues (not sure what the deal is on tow stability either..) They aren't deal breakers, but I would rather have t working as it should.
The LR one is also just wires and plugs so should be the same.
i remember reading that the 2012 is plug and play and you dont need to do anything to the ccf....but theres only one way to find out, is to fit the electrics and see..
