Home > Group Buys > Bottle jacks with metal blocks
Sign Up
(14)
User Registered Confirmed
gj8829th Nov 2018 11:12pmgj88 is confirmed
Harlequin30th Nov 2018 5:54amHarlequin is confirmed
alanm_330th Nov 2018 10:49pmalanm_3 is confirmed
heppsen1st Dec 2018 6:48pmheppsen is confirmed
Roadking2nd Dec 2018 9:46amRoadking is confirmed
kooky_guy4th Dec 2018 7:53amkooky_guy is confirmed
Squirrel21st Dec 2018 8:11pmSquirrel is confirmed
dirtymonkey3819th Jan 2019 7:58pmdirtymonkey38 is confirmed
jonlewis20th Jan 2019 7:51pmjonlewis is confirmed
Davlyn22nd Jan 2019 9:16pmDavlyn is confirmed
chief647th Feb 2019 7:53pmchief64 is confirmed
scsykes24th Feb 2019 7:44pmscsykes is confirmed
gavinn8th Mar 2019 7:35amgavinn is confirmed
Webbie9th Mar 2019 5:41pmWebbie is confirmed
Page 2 of 5 <12345>
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Ok, I've activated the sign up again, please add yourself if you like some done, I think we need 3 signed up to make it work
Bushy Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #497094 29th Nov 2018 10:40pm
GI JIM
United Kingdom 2004 Range Rover Vogue 4.4 V8 Buckingham Blue
Already on Aluminium Jacking Pad thread Thumbs Up May The FFoRRce Be With You
Post #497115 30th Nov 2018 9:55am
GI JIM
Already on Aluminium jacking pad thread Thumbs Up May The FFoRRce Be With You
Post #497116 30th Nov 2018 9:56am
GI JIM
2 times Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter May The FFoRRce Be With You
Post #497118 30th Nov 2018 9:57am
Bushy30
OK chaps -- group buy in progress -- currently 1 unit spare up for grabs Smile
Previous: -
Post #497120 30th Nov 2018 10:16am
phil67
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
Im in the middle of buying my first Range Rover Sport on an 09 plate, so may be interested if it fits?
Post #497171 30th Nov 2018 8:08pm
Bushy30
Sorry Phil I don't know! Perhaps the sport forum folk might know Smile Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #497189 30th Nov 2018 10:32pm
heppsen
Germany 2012 Range Rover Vogue TDV8 Santorini Black
I have signed myself up in here as I like the idea of having a jack whcih actually would work, but I d rather nit have the Speinter jack sent back to Germany. Could I get the adapter only? Would I be abke to add it myself?
Regards
Heppsen 2017 MB V-Class
2016 Q7 (gone)
2012 FFRR TDV8
2012 Smart Pulse Turbo
1986 MB W126
1965 LR Series 2A
1961 LR Series 2
Post #497245 1st Dec 2018 6:49pm
Bushy30
Heppsen, the block is available on eBay, search for BMW, mini Wink
Attaching it is the difficult, engineering bit that's required
Previous: -
Post #497250 1st Dec 2018 7:36pm
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
What range of lift does a bottle jack need to comfortably lift a L322 for tyre change?
Jim
Post #497252 1st Dec 2018 8:35pm
Baltic Blue
Sorry Jim, I don’t the answer to your question, but I do know....
(1) It doesn’t want to be any taller than a sprinter jack in the fully down position, otherwise you will struggle to use it when the tyre is flat, I.e. to change a puncture.
(2) The maximum lift of a sprinter is perfect for removing a fully inflated wheel.
I think you will find it hard to get a better solution than the sprinter which works well.
I have seen a triple lift jack that is actually not quite as tall as a sprinter, so fits in easier to remove a flat and yet reaches the same maximum lift. The problem with it was it was rated at 20 tonnes, so VERY expensive , and weighed a ton, so not good to keep in car, more of a Workshop jack.
Post #497300 2nd Dec 2018 9:05am
phil67
Well no need to worry about the rrs size as ive decided on a full fat model now Smile
Post #497379 2nd Dec 2018 10:59pm
Bushy30
Thumbs Up Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #497390 3rd Dec 2018 8:43am
GI JIM
As many of us have various size wheel rims some FF will be sitting lower with 18" Rims than those with 22" Rims.
So the Jack height question will depend on that factor. Its answer is always in the MATH Whistle Big Cry May The FFoRRce Be With You
Post #497399 3rd Dec 2018 10:30am
kooky_guy
I've signed up now as I know that I'll need one if I don't!
Thanks for the PM Bushy, but that one didn't have a handle and the seller wasn't very communicative. 2010 4.4 TDV8 Vogue SE
Post #497524 4th Dec 2018 7:56am
Page 2 of 5 <12345>
