Home > Maintenance & Mods (L322) > nearside suspension just collapsed |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 |
It's going to be either the bag or the hose / connector as you say.
21st Nov 2018 12:12pm |
Snowy90 L322 Member Since: 24 Aug 2015 Location: Surrey Posts: 220 |
The hose is right at the top isnt it?
21st Nov 2018 12:16pm |
gj88 Member Since: 10 Sep 2018 Location: West Midlands Posts: 213 |
My bag went under literally identical circumstances. In normal and access height the bag has some overlap in the bottom half, if you take it up to offroad height it becomes single walled and any perishing is likely to let go at this point. I'd be really surprised if it wasn't the bag, but definitely worth checking the hose first. Mine also wasn't a soap and water job to find the split, I could have fit my head in the hole left! |
21st Nov 2018 2:28pm |
Also, if you're changing one bag, change the other side too |
21st Nov 2018 2:29pm |
Im pretty sure its going to be the bag, so ordered a replacement from Island4x4, so back on the spanners! |
21st Nov 2018 2:37pm |
Swipe Member Since: 31 Aug 2018 Location: Rustington, West Sussex Posts: 101 |
As gj88 says change in pairs.
21st Nov 2018 5:10pm |
Hopefully someone can help.
28th Nov 2018 2:20pm |
Ok so found a site that explained the order of the washers and it looks like they sit just below the threaded part of the shock and insert into the underside of the rubber top mount.
28th Nov 2018 6:06pm |
gg2201 Member Since: 21 Oct 2013 Location: Callington Posts: 158 |
Did you replace the air line fitting with a new one?
30th Nov 2018 12:50pm |
Sorry i started a new thread just on the leak!
30th Nov 2018 3:42pm |
