![]() | Home > Wheels & Tyres > What wheels fit L405? |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3767 ![]() ![]() |
You need a set of 20” L405 standard wheels and AT tyres. I have Cooper AT3 285/50/20 on mine for the shooting season - summer set are the Turbine 22’s 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35545 ![]() ![]() |
these are the type you want, loads on ebay ..
Charles89 Member Since: 11 Nov 2018 Location: Leicester Posts: 268 ![]() ![]() ![]() |
Thank you for the reply... the big question I'm looking to answer is, are all range rover wheels the same PCD and fitment etc.?
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 899 ![]() ![]() ![]() |
Yes |
Thank you |
The offset is different - they will look crap 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7977 ![]() ![]() ![]() |
Are they different ?
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1396 ![]() ![]() ![]() |
Dan@Duckworths had two sets of 20" 405 wheels for sale in October, admittedly with standard summer road tyres, but well priced at £1,000 I think, they might still be available, you could keep the tyres for the summer and fit something more robust. I have Goodyear Duratrac 255/55R20 on a set of wheels from Dan, acquired in that way, was very pleased with service and value there. Only Range Rovers since 1988 |
Yes they are different ![]() 322 wheels will catch on full lock - especially with wider tyres - you are also losing nearly an 1” on track width 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
I suppose you could use 10mm spacers if you were really set on using L322 wheels, although I'd stick with L405 20" wheels, they're plentiful on ebay as already said. |
10 mm Spacers like that are not recommended = 10mm less thread in your wheel nuts = not much holding your wheels on. The only way with spacers of that size is to also change your studs for ones 10mm longer 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
Thanks for all the input. I will look for some L405 wheels that won't great the bank. If I ever did use spacers it would only ever be hubcentric ones anyway. But I would rather not use spacers.
How do you find the ride/road noise ? |
