Home > Wheels & Tyres > What wheels fit L405?
Charles89
United Kingdom 2014 Range Rover SVAutobiography SDV8 Scotia Grey
I currently have 22" wheels and I learned the hard way yesterday that these wheels and tyres are far from capable off road... in my L322 I had 20" wheels fitted with 255 60 20" they were winter/AT fantastic tyres. My 22" on the L405 has continental tyres brand new X4 and one burst yesterday at the fist sight of a rock on a green lane in the dales..
Can I fit L322 wheels that seem to be plentyfull on eBay? I need a set of rugged capable wheels and tyres. And advice would be great thanks
Post #496537 25th Nov 2018 8:37am
Vogue
You need a set of 20” L405 standard wheels and AT tyres. I have Cooper AT3 285/50/20 on mine for the shooting season - summer set are the Turbine 22’s 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #496546 25th Nov 2018 10:16am
these are the type you want, loads on ebay ..
Post #496550 25th Nov 2018 10:30am
Charles89
Thank you for the reply... the big question I'm looking to answer is, are all range rover wheels the same PCD and fitment etc.?
I have the opportunity to buy some 20" range rover wheels from a 2009 range rover, which I will fit some relatively aggressive snow tyres to
I am looking at a set of 265 60 20 tyres which according to will they fit, tells me they will provide an additional 20mm lift In ride hight while at 30mph it will display 29mph only a 1mph incorrect reading which I can live with.
So... will older range rover wheels fit my L405?
Post #496557 25th Nov 2018 10:50am
JCW
United Kingdom 2012 Range Rover Autobiography TDV8 Sumatra Black
Yes Thumbs Up
Post #496565 25th Nov 2018 11:32am
Charles89
Thank you Smile
Post #496566 25th Nov 2018 11:37am
Vogue
The offset is different - they will look crap 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #496577 25th Nov 2018 1:27pm
Are they different ?
I saw an L405 with L322 wheels - photo here - and it looked OK
Post #496604 25th Nov 2018 6:24pm
CS
Dan@Duckworths had two sets of 20" 405 wheels for sale in October, admittedly with standard summer road tyres, but well priced at £1,000 I think, they might still be available, you could keep the tyres for the summer and fit something more robust. I have Goodyear Duratrac 255/55R20 on a set of wheels from Dan, acquired in that way, was very pleased with service and value there. Only Range Rovers since 1988
Post #496614 25th Nov 2018 7:05pm
Vogue
Yes they are different Thumbs Up L322 have an offset of 58mm, L405 are 49mm for 22” wheels and 47mm for 20” wheels, i.e. for 20” wheels there is 11mm difference.
322 wheels will catch on full lock - especially with wider tyres - you are also losing nearly an 1” on track width 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #496637 25th Nov 2018 9:10pm
Bow down I didn't know that Thumbs Up
Post #496642 25th Nov 2018 10:21pm
JCW
I suppose you could use 10mm spacers if you were really set on using L322 wheels, although I'd stick with L405 20" wheels, they're plentiful on ebay as already said.
Post #496643 25th Nov 2018 10:26pm
Vogue
10 mm Spacers like that are not recommended = 10mm less thread in your wheel nuts = not much holding your wheels on. The only way with spacers of that size is to also change your studs for ones 10mm longer 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #496644 25th Nov 2018 10:32pm
Charles89
Thanks for all the input. I will look for some L405 wheels that won't great the bank. If I ever did use spacers it would only ever be hubcentric ones anyway. But I would rather not use spacers.
Only reason I asked is I have the chance to buy full set for 300 including tyres local to me. But if L322 wheels won't really work then it's back to the drawing board
Post #496648 25th Nov 2018 10:51pm
Charles89
How do you find the ride/road noise ?
Post #496733 26th Nov 2018 10:51pm
