Home > Technical (L405) > L405 4.4 SDV8 Drive Train
Bry B
United Kingdom 2014 Range Rover Vogue SDV8 Santorini Black
Hi Guys new to this group thanks for adding me, my first question is my 2014 4.4sdv8 has a quite noticeable drive train thump when on and off the gas at low speed and sometimes on the motorway , I’m thinking transfer box wear but the dealer is saying that LR advise a two flush of the transfer box will sort it, I’m not convinced it seems more mechanical than fluid, I’m not unduly worried as she’s covered by LR extended warranty, just wondered had anyone else experienced the same problem, she’s only done 42k miles. Thanks in advance
Bryan
Sheffield
UK
Post #495761 16th Nov 2018 8:08pm
Welcome Thumbs Up
If it’s on warranty, then I think you’ll have to let them try their fix first. Always possible there is some crap in the fluid that is affecting the movement of a mechanical component.....
Post #495762 16th Nov 2018 8:20pm
Bry B
Thanks Alistar but the problem feels more like a worn component than a bit of swarf floating around the transfer box. It’s the delay in the prop taking up the torque from the gearbox that’s the problem . I’m going to let them do what they think always with Land Rover the cheapest fix first but I’m sure it’s no going to work. The previous visit I had to tell them the problem with the suspension knocking they replaced numerous bushes until i told them the ARC valve block was the fault Ann’s sure enough they changed it. These days they are not mechanics but fitters
Post #495769 16th Nov 2018 9:26pm
GraemeS
A double flush then a re-calibration of the transfer case motor, not just a double flush. Its a known problem.
Post #495771 16th Nov 2018 9:41pm
Bry B
Thanks for that Graeme you’ve elaborated on the 19 year old service guys explanation. Will see, the other thing is there’s a strong smell of exhaust gases in the cabin when the car get upto temperature any views on that as it’s now been in twice and they have no clue. I’ve been advised a split egr pipe
Post #495773 16th Nov 2018 10:23pm
GraemeS
Sorry, I can't help with the exhaust smell or comment on the possibility of a split EGR pipe. However its common for a fault for the EGR temp sensor A to be recorded which may add to any exhaust odours. The EGR temp sensor A fitted in production has been revised twice.
Post #495776 16th Nov 2018 11:23pm
Bry B
Thanks Graeme . Appreciate the temp sensor heads up. It’s disapointing that we have to self diagnose faults when booking in for a dealer prognosis.
Post #495778 17th Nov 2018 1:19am
