Home > Technical (L405) > Engine bay cover.
Huwrhys
United Kingdom 2017 Range Rover Autobiography SDV8 Loire Blue
Engine bay cover.
Do I have a cover missing to the l/h/f corner above the washer bottle?
If so does anyone know the name or part number for it?
Thanks in anticipation.
Huw
Post #494551 3rd Nov 2018 10:07pm
MJGH
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
Just been out to look.
If you have one missing then so do I as mine is the same Smile
Post #494558 3rd Nov 2018 11:05pm
Huwrhys
Thanks for looking. It was the bracket far left that made me question if something was amiss as well as the lip that runs behind the rubber seal.
Post #494571 4th Nov 2018 8:17am
Yours (& mine) had the extra large capacity washer bottle fitted sir... The bracket would allow the blanking cover to be fitted if you didn't have the optional extra fitted Thumbs Up
Post #494600 4th Nov 2018 3:02pm
Huwrhys
Nice one, thanks for the explanation. Thumbs Up
Post #494606 4th Nov 2018 3:42pm
Post #494616 4th Nov 2018 5:21pm
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
Slightly confused, I thought the only option was an 'extra large additional water bottle', so can you also specify an extra large normal washer bottle aswell? On my car, I have 2 washer bottle filling points, one in the picture you show above, and one in the drivers side wing outside of the engine bay? Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #495522 13th Nov 2018 11:24pm
Yes there are two filling points sir... If you look carefully at pic1 above you can just see the second filler in the top left corner of the pic... Thumbs Up
Post #495523 13th Nov 2018 11:37pm
RRVSE
Ah yes, good point Craig, cheers Smile Steve
Post #495774 16th Nov 2018 10:39pm
