Home > Maintenance & Mods (L322) > Wiring an Inverter
carl
2005 Range Rover Autobiography 4.4 V8 Java Black
Wiring an Inverter
Hey Guys
i have an inverter that i'd like to fit in the boot to run an Xbox from time to time.....sadly the rear socket won't give the required amps so i was wondering about using the rear fuse wiring as i seem to recal a post on using this for a twin battery set up.....would this work? and since i find electrics all voodo and witchcraft can anyone give me a bit of an idiots guide?......please....
thanks Carl
p.s i know search is my friend but since i can remember where i read about this hours of searching have about turned me grey....
Post #49423 8th Feb 2011 11:54pm
dan_uk_1984
Hi Carl,
If you look behind the right hand panel in the boot you will see a chunky red cable, this feeds the rear fuse board. You can use this for your +, and then find an appropriate place to earth to. If you pull out the liner for the right hand storage bin (lift out) you will have loads of space.
A word of warning though, if the amp draw is that heavy then your battery will go flat in no time at all. Perhaps look at installing a second battery? It needn't be a great one, I will sling one in there next time I see a cheap battery come up locally on fleabay.
Dan
Post #49428 9th Feb 2011 8:21am
Optima Yellow Top Leisure batteries are very good indeed Thumbs Up (worth the extra)
Post #49433 9th Feb 2011 9:19am
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
I'd do a check on reviews of the optima batteries. As I understand it they are only any advantage in a Landrover in so much as you can park upside down and not worry about acid leakage. Otherwise any good leisure battery will perform the same. I haven't had a personal experience but have seen the views of other Landrover 101 owners after using several of these when they were recommended on the 101 circuit and quite a few jumped onboard. 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #49446 9th Feb 2011 10:53am
dan_uk_1984
Optima are great, they last ages, but are very expensive. I took the view that I would rather replace my battery more frequently rather than pay out the extra. As I usually only keep a car for 2 or 3 years it's normally not an issue.
Post #49452 9th Feb 2011 11:42am
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
So, has anyone fitted an Optima as the main battery?. If so which one and what is the performance like?. Is it as claimed on the website?.
Post #49455 9th Feb 2011 12:04pm
elpeede
No.
But do have a Read of this. 2010 Disco XS TDV6, 2009 Freelander 2 GS
Post #49465 9th Feb 2011 12:37pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Is the chunky red cable fused? If not make sure place an inline fuse in the inverter cable very close to where tap into the red cable to avoid a burnt out Range Rover.
Cheers
Justin
Gone - Range Rover Supercharged 2006
Post #49496 9th Feb 2011 6:29pm
carl
hey guys
Thanks for the replies may even have a look tomorrow now.....i need a new main battery anyway as its let me down three times already.....a second battery may be a plan tho....also i do think the invertors fused so wondering if another fuse is needed or not?
thanks carl
Post #49537 9th Feb 2011 11:07pm
JustinP
if the inverter fuse is in the inverter case rather in the cable, theres a risk the cable could chafe on something causing an unprotected short.
Cheers
Justin
Post #49538 9th Feb 2011 11:11pm
dan_uk_1984
The feed to the rear fuse box comes from the battery, via the front fuse box where it passes through a 100Amp fuse.
The Accessory socket (front and rear) both get their feeds from the rear fuse board and are fused to 20A each. You could safely draw 50A off the cable without risking overloading it, or popping the 100A fuse.
If you need anything more than 60Amps I would suggest that you run a seperate cable. I would still suggest the second battery option. If your old battery will fit in the 2nd battery space the it would make sense to use that as it obviously still works.
Rear Fuse by d86cfv, on Flickr
Post #49565 10th Feb 2011 9:09am
just a headsup, asda have a 75 watt [150watt peak] plug in inverter reduced to £5 if its any help.. ... - .- -.
Post #49570 10th Feb 2011 9:32am
dan_uk_1984
Worth noting that at 150Watts the maximum amp draw on that would only be 12.5A, the larger 300W inverters will only draw 25A so the wiring there will easily cope with that.
The biggest inverter I can fins is 1000W, but at 83A the alternator wont be able to keep up with demand and you risk damage.
Post #49575 10th Feb 2011 9:58am
elpeede
Dan, is the ampage of the cable the total realistic loading without letting out the magic smoke or the spare loading assuming every other possible item running off the rear fuse box is switched on and doing its stuff Question 2010 Disco XS TDV6, 2009 Freelander 2 GS
Post #49584 10th Feb 2011 11:25am
dan_uk_1984
The total allowable ampage on the circuit going by the fuse installed is 100amps - generally the cable will be rated higher than the fuse?
Being that the cable/fuse has to allow for 40amps of accessory power on two sockets I think its safe to use that as a guide, plus everything else that runs on that circuit.
I wouldn't recommend drawing 40 amps in the two accessory sockets and then running a high power inverter. Common sense should always prevail.
Post #49589 10th Feb 2011 12:14pm
