Home > Technical (L322) > Brake Fluid loss
cgarside
United Kingdom 2008 Range Rover Vogue TDV8 Stornoway Grey
Brake Fluid loss
Hi,
I have a 2008 TDV8 which has covered circa 94000 miles.
I recently had a brake fluid warning come up and noted the the master cylinder level was low. I hoped this had occurred due to pad wear as there was no signs of external leakage. I added more fluid and after twelve days I now have another low brake fluid warning showing in the dash. Again, now signed of external leakage showing.
Has anyone had a similar problem and / or is there a known problem at this age / mileage?
Regards
Chrisk 08 Range Rover TDV8 Vogue
Post #494988 8th Nov 2018 11:37am
I had the very same isssue. Seems unusual that there aren’t any brake fluid leaks on the ground under any part of the car?
Mine turned out to be a cracked brake pipe at the rear of the car. Got - 2017 SDV8 Autobiography in Loire Blue
Post #494992 8th Nov 2018 11:47am
cgarside
Ok, thanks
Will get the car off the ground and inspect more closely
Chris 08 Range Rover TDV8 Vogue
Post #495003 8th Nov 2018 2:07pm
fisha
most common place seems to be the rear pipes as they run across the top of the fuel tank area. So leaking fluid will spread about on things.
Also the pipes run behind a couple of plastic guards which may be catching the fluid. It should be easy enough to spot if you go looking. V8 or else ...
Post #495009 8th Nov 2018 2:56pm
the fluid has gone somewhere, so I would get it up in the air.
there are several places that the pipes corrode, as said, over the tank, under the passenger side plastic cover which runs the length of the car. But also check the front wheel arches, there its bend in the metal pipe which is very prone to corrosion, both of mine were dodgy on my 07 and that was a few years back...... There is nothing that can't be fixed with a hammer😜😜
Post #495109 9th Nov 2018 5:19pm
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Just had MOT to night advisory brake pipes corrosion front pipes 55 plate am i on borrowed time................... Sad
Post #495116 9th Nov 2018 5:54pm
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
Sadly yes,
I had advisories for all 4 lines, last year I replaced the brake pipes with 90/10 Cupro-Nickel. When I removed the
old steel ones they snapped in half in areas that had been secured by pipe clips in hidden areas. If one area has been flagged I guarantee there are more. Do a search for "how to", Joe 90 did a great detailed write up.
Original brake pipes (front nearside)
Post #495120 9th Nov 2018 7:47pm
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
2007 client car...., last year. L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #495172 10th Nov 2018 4:42pm
