Home > Technical (L322) > Brake Fluid loss |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6733 |
I had the very same isssue. Seems unusual that there aren’t any brake fluid leaks on the ground under any part of the car?
8th Nov 2018 11:47am |
cgarside Member Since: 25 Mar 2015 Location: Preston Posts: 21 |
Ok, thanks
8th Nov 2018 2:07pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1379 |
most common place seems to be the rear pipes as they run across the top of the fuel tank area. So leaking fluid will spread about on things.
8th Nov 2018 2:56pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8632 |
the fluid has gone somewhere, so I would get it up in the air.
9th Nov 2018 5:19pm |
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 602 |
Just had MOT to night advisory brake pipes corrosion front pipes 55 plate am i on borrowed time................... |
9th Nov 2018 5:54pm |
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 503 |
9th Nov 2018 7:47pm |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 316 |
10th Nov 2018 4:42pm |
