Home > Technical (L322) > Help please - whining TDV8
WB
Hi,
Hoping for some help please in diagnosing this whine which I noticed yesterday. It's a 2008 TDV8 Vogue (59k miles).
The whine seems to occur at any engine speed above idle - whether driving or parked.
I've done some googling which leads me to think it may be alternator related possibly but would appreciate any wisdom anyone can offer please? I understand the car had a new alternator fitted about 3 years ago by the previous owner.
Thanks for any help
Post #494526 3rd Nov 2018 3:52pm
Boxbrownie
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
Sounds very much like mine when first bought @89K it turned out to be the FEAD belt tensioner, all nice and quiet after replacement.
The specialist that replaced it said it was very rough and noisy when removed. David
Please let me know if my comments upset you, I may wish to upset you again.
Post #494590 4th Nov 2018 1:26pm
WB
Thanks for that - do you mind me asking the replacement cost? I was beginning to suspect something other than the alternator as the noise is barely there at idle.
Post #494591 4th Nov 2018 1:28pm
Boxbrownie
I think it was about £80 but it was done at the same time as a few other bits, so a bit difficult to separate the accurate cost. David
Post #494592 4th Nov 2018 1:36pm
WB
Thanks again, do you know if it's this one by any chance - I can't find a part called the FEAD belt tensioner? Just trying to figure out where to look.
PQG500160
Post #494621 4th Nov 2018 6:01pm
Could be the belt tensioner as said or possibly a bearing on something at the front of the engine, water pump/alternator etc.
You need to get in there and have a closer listen to where it is coming from. There is nothing that can't be fixed with a hammer😜😜
Post #494634 4th Nov 2018 7:55pm
WB
Thanks, will do
Post #494640 4th Nov 2018 8:17pm
Boxbrownie
I do not have the part number I am afraid, but as said above it could be almost anything in there, my specialist needed to dismantle before they were sure so can be difficult to pinpoint. David
Post #494693 5th Nov 2018 12:25pm
Boxbrownie
Not sure what Landrover would call,it, we called it FEAD, it is also known as the Serpentine Belt or Multi Vee belt......it’s the accessory drive belt, sometimes there are even two! David
Post #494694 5th Nov 2018 12:28pm
WB
That's great, thanks for that. I'm taking it in tomorrow but hopefully that will help narrow it down.
Post #494723 5th Nov 2018 5:36pm
WB
Just got back from the mechanic. It sounds like it's coming from the power steering pump but he said difficult to know for sure if its the power steering pump or something else in that area until its taken apart. He also spotted the power steering fluid was on the MIN mark so topped that up but it didn't make a difference to the noise.
Post #494784 6th Nov 2018 12:14pm
whining on the PAS pump usually occurs with steering load rather than revs, but its something on the drive belt. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #494800 6th Nov 2018 5:37pm
WB
Thanks that makes sense, it doesn’t vary while steering although there is a little ‘chirping’ on full lock.
Hopefully will find the culprit somewhere along the belt!
Thanks for all the advice folks
Post #494803 6th Nov 2018 5:47pm
WB
Thanks for all the help folks. It was one of the Idler Pulleys. Took the mechanic about an hour to take out the air box, fan and belt then diagnosed it to the pulley. Fortunately local dealer had one in stock.
Post #495678 15th Nov 2018 7:58pm
Nice relatively cheap fix There is nothing that can't be fixed with a hammer😜😜
Post #495684 15th Nov 2018 9:00pm
