Home > Maintenance & Mods (L322) > Common oil leak places?
Danwilderspin
So I’ve done the pcv both rocker covers and thought the oil leak was gone as no drips on the drive however tightening my tensioner when I took the under tray off the bottom of the engine looks like this? The under test didn’t look too bad.. I guess it could be residual but after 6 months would it still be like this? If not what other common places for leaks?
 Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #494602 4th Nov 2018 3:22pm
Danwilderspin
Had another look it seems to be more on the passengerr side bank... Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #494622 4th Nov 2018 6:02pm
Wouldn’t expect drips as you can see in the second pic after that long. There is nothing that can't be fixed with a hammer😜😜
Post #494637 4th Nov 2018 8:03pm
srpara
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
As nmj said above.
Would it be worth cleaning off all you can then recheck in a few weeks to see if you have fresh oil on that area again
Post #494721 5th Nov 2018 5:31pm
holidaychicken
Upper timing chain covers and vanos solenoid seals are a favourite
Post #494757 5th Nov 2018 11:43pm
mpirie
srpara wrote:
As nmj said above.
That would be my approach too.
The thing is, oil can spread itself around very easily, so it could be some spill from an earlier oil change!
Apply some Gunk or other engine degreaser brush it in and wash it off. Then keep an eye on it to see where any fresh oil is coming from.
Mike
Post #494767 6th Nov 2018 8:47am
srpara
mpirie.....two great minds Very Happy Very Happy Thumbs Up
Post #494773 6th Nov 2018 9:30am
ohuntsman
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
My Cam covers were loose at the rear and leaking
Post #494788 6th Nov 2018 1:31pm
Danwilderspin
That bank I got the garage to change after I pinched the gasket first time round - maybe worth me checking they correctly tightened... Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #494834 6th Nov 2018 9:19pm
