Home > Maintenance & Mods (L322) > Rear window seal corrosion |
marsie Member Since: 30 Apr 2010 Location: sheffield Posts: 916 |
Had the same issue with my 2011 and posted on here.
28th Sep 2016 9:58pm |
johnb8538 Member Since: 15 Sep 2016 Location: Glasshoughton Posts: 71 |
It does look better. |
28th Sep 2016 11:41pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1385 |
I'm not sure about that, I have had the telescopic struts replaced under warranty and the replacements are now rusty too. They lasted much longer on my 2004 car with similar use, so I'm guessing the paint is poorer quality, perhaps due to regulations designed to protect the environment. My rear window trims were also replaced (twice) under warranty due to corrosion, the latest set seems not to be corroding yet. Only Range Rovers since 1988 |
6th Oct 2016 1:43pm |
By chance the dealer I just purchased the car from read this thread I sent to them and managed to get me a set of trims FOC from Landrover. They did say it took some doing as Landrover still stated it wasn't a corrosion issue.
6th Oct 2016 9:01pm |
Couldn't have been easier, slip off, slip on with two 3M sticky tabs on each end.
8th Oct 2016 7:13pm |
CaptSlow Member Since: 07 May 2018 Location: Kent Posts: 1 |
Hi all, recently bought my RR with similar issue, but replacement parts thrown in also..
7th May 2018 5:06pm |
En Vogue Member Since: 22 May 2014 Location: Munich Posts: 41 |
+1 I am interested in that too. Is it really that easy to fix/slide the new parts in? Instagram @l322passion |
1st Nov 2018 8:22pm |
drakes Member Since: 26 Jan 2009 Location: Consett Posts: 370 |
I recently swapped my 2004 for a 2010. The 2004 had a trim across the bottom of the glass but no trims at the side however the 2010 had the side trims (corroded and now replaced) but no bottom trim. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
1st Nov 2018 10:01pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3167 |
Common issue - they are £32 each side to replace! I will find the part number if anyone wants it. |
2nd Nov 2018 9:03am |
