![]() | Home > Maintenance & Mods (L322) > Rear window seal corrosion |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35629 ![]() ![]() |
that is indeed the corrosion problem Andy.. ... - .- -.
Van Diesel Member Since: 27 Oct 2013 Location: Norfolk Posts: 183 ![]() ![]() ![]() |
Nice one Stanley !! |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
just had a look at mine and they are the same... |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 818 ![]() ![]() |
mine are being replaced under general warranty.
cloudwind Member Since: 01 Nov 2011 Location: Hertfordshire Posts: 20 ![]() ![]() |
Hi
simonreed Member Since: 14 Jun 2016 Location: hampshire Posts: 11 ![]() ![]() ![]() |
Hi - I have the same problem but no warranty, does the window mount on-top of the seal and therefore you have to have the window off to replace?
rear screen stays where it is , the trims just pull off and the new ones slide back on.. ... - .- -.
thanks |
johnb8538 Member Since: 15 Sep 2016 Location: Glasshoughton Posts: 71 ![]() ![]() ![]() |
2011 Autobiography in lovely condition let down by these silly strips.
I would just take them off and not replace them. Looks better and my old 2008 didn't have them. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8749 ![]() ![]() ![]() |
Yep, as above. Just pull them off an put them in the bin. Earlier cars didn't have them and they serve no purpose other than to rust.... There is nothing that can't be fixed with a hammer😜😜
Thanks gents. After looking today I see they do indeed serve no purpose regards insulation. The previous owner attempted to glue the corroded ends down and made them look worse so it will take some cleaning once I work them off.
TomCobbly Member Since: 29 Jun 2016 Location: Guildford Posts: 122 ![]() ![]() ![]() |
I got mine here...http://www.ebay.co.uk/itm/201649316136?_tr...EBIDX%3AIT
Yep, that's the same listing I found.
