Home > Technical (L322) > L322 2004 4.4 Trans Fail Safe fault locked in 4th gear fault |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 962 |
The bearing fault would lock the transmission in 5th so you should certainly proceed along the faulty solenoid route. I’ll stick one in the post to you today.
29th Oct 2018 8:59am |
Knightrider Member Since: 22 Mar 2014 Location: England Posts: 125 |
Thanks Phil much appreciated 2004 Range Rover Vogue 4.4 v8 LPG, Java Black, 22' Hawke Alloys, Black Beast |
29th Oct 2018 12:15pm |
No, we still have no idea whether it’s a wiring issue or the solenoid itself. Substitution with a known good solenoid is the easiest way to determine this. It should arrive in the post tomorrow.
29th Oct 2018 5:55pm |
Yeh I agree that makes sense, fingers crossed the replacement solenoid fixes the problem, if it doesn't I guess it will be sump off again and replace the wiring loom which will mean extra spend on more gearbox oil/gaskets but it's not the end of the world.
29th Oct 2018 7:11pm |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
Would it be worth checking the connections on the external plug and socket before strip down just in case of corrosion etc, maybe even try disconnecting and reconnecting a few times? BMW i3 Electric Car
29th Oct 2018 7:14pm |
Yes, good idea. Certainly wouldn’t do any harm. I guess you’d be looking for corrosion on the No. 9 pin (as pin 16 is used as the power supply for the other two shift solenoids, as well as two of the proportional (EDS) solenoids, so unlikely to be that).
29th Oct 2018 11:48pm |
A quick update I'll be taking the car to a mates garage on Wednesday to replace the shift soleniod with him as he hasn't done one before. In the meantime the wife has been using the car for her short 3 mile commute to work and the error code has come up I would say on half the journeys so it seems to be unpredictable and not necessarily gearbox oil temperature linked as the gearbox fluid is only just warming up after a couple of miles..
2nd Nov 2018 6:12pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
looking forward to your resolution as it is not a 'common' fault |
2nd Nov 2018 8:53pm |
Hi guys I had the soleniod replaced yesterday and it has fixed the problem, I've done approx 100 miles since and had no further Trans fail messages.
10th Nov 2018 9:30pm |
Top work.
10th Nov 2018 11:07pm |
Very pleased to hear that you are sorted. If you get chance to send me the duff solenoid I’d be interested in testing it to see what was wrong with it
10th Nov 2018 11:40pm |
No problem Phil I kept hold of the removed soleniod for you, I'll pop it in the post to you on Monday 2004 Range Rover Vogue 4.4 v8 LPG, Java Black, 22' Hawke Alloys, Black Beast |
11th Nov 2018 12:17am |
Hrmn Member Since: 14 Oct 2016 Location: Hoogeveen Posts: 3 |
I have exactly the same fault with the same symptons. After 15 km drive when the gearbox oil is 85 C it goes into fail save 4th gear. And giving solenoid valve fault. Only to remove when box is cold.
8th Apr 2019 7:31pm |
Some more information on the above post.
14th Apr 2019 9:18pm |
