Home > Technical (L322) > Opinions Requires On Strange Fault
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Hi,
Went to open my L322 (07MY SC) this morning and the alarm went off and doors would not open, opened with key and alarm still going, after repeated tries to silence the alarm with the key fob it eventually started working after about 30 seconds.
Got in and started fine but noticed CD had changed to radio, all stations lost from memory, trip distance meter reading zero and date /time set to midnight 01/01/2015 - seemingly all settings reset.
Drove fine, restored all settings as I drove but when I removed key from ignition it did it again, this time minus the alarm - no interior lights, unable to lock - after repeated tries for 30 seconds or so it started working again.
Not yet checked with my IID Tool but I suspect my BCM is at fault.
Anyone had similar or input on subject?
Thanks
Post #493826 28th Oct 2018 7:16am
Battery/alternator check first, check the connections as well.
Then dig deeper. Lots of things like this caused by bad voltage. There is nothing that can't be fixed with a hammer😜😜
Post #493828 28th Oct 2018 8:44am
Katash
Think your probably right, working ok now but gonna stick the battery on charge tonight first.
Post #493845 28th Oct 2018 10:37am
Gremlins, water ingress, other
You may never find it Embarassed .
Post #493849 28th Oct 2018 11:08am
Reading it again, first port of call would be to clamp up the battery terminals. Sounds like it’s dropping it’s power supply when off hence the reset.
Try a battery reset and fit everything back on good and secure and it probably won’t happen again.... Whistle There is nothing that can't be fixed with a hammer😜😜
Post #493872 28th Oct 2018 1:39pm
