Home > Technical (L322) > anyone got the calibration measurements for suspension
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Just fitted a new compressor and the back looks lower than the front, its had a lot of work done so id liek to check the suspension measurements.
I saw a photo/chart showing what all the settings should be for different wheel sizes (I have 22" on at present)
Does anyone have a copy of it they could post please?
Post #493672 26th Oct 2018 2:02pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
This might help
http://www.fullfatrr.com/forum/topic44640....hth+height Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #493676 26th Oct 2018 2:16pm
mrblonde
Thats the one Bushy30, many thanks Thumbs Up
Post #493685 26th Oct 2018 3:01pm
Wheel sizes were important in the early days when we were measuring from the bottom of the wheel rim to the wing. now we measure from the hub centre, all standard fit wheels and tyres should have the same circumference, thus radius/diameter. However you may need to do some calculations for 22" wheels .
Post #493699 26th Oct 2018 5:30pm
mrblonde
Cheers Joe
Pretty sure the diagnostic tool my mate had showed 760mm (or thereabouts) as one setting, so guessing it measures the earlier way, from bottom of the rim to wheel arch
Post #493701 26th Oct 2018 5:36pm
Post #493704 26th Oct 2018 5:43pm
