![]() | Home > Technical (L322) > L322 4.4 TDV8 Air Conditioing problem |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
In the past I have used excellent agricultural engineers, most new tractor and harvesters have now got aircon and they did a really thorough job at sensible prices. Have a look around for a Massey Ferguson or JCB dealer. BMW i3 Electric Car
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
Sounds like you have a leak somewhere. They should do a full vacuum test on it though before re-gassing. There is nothing that can't be fixed with a hammer😜😜
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
Sounds like the common fault with the compressor pressure valve.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
My money is on the above. 2011 Range Rover Vogue SE 4.4 TDV8
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
If there are no leaks then it does sound like he compressor control valve.
I did the opposite - and just changed the valve - but, it's a good full day's work (or was for me). |
London Rangie Member Since: 16 Feb 2015 Location: Hatfield Posts: 6 ![]() ![]() ![]() |
Thanks to everyone. I have now read the other thread. I think a replacement of the compressor and valve should do the trick. |
I think the new compressor will come with the valve already fitted. |
