Home > Technical (L322) > L322 4.4 TDV8 Air Conditioing problem
London Rangie
United Kingdom 2008 Range Rover Vogue TDV8 Buckingham Blue
I have an air con problem on my 2012 4.4 TDV8 Westminster. It has been getting worse over the last two years and now the air con barely gets even cool and certainly never cold. The inside front screen often mists up too.
I have twice had the air con regassed but it has not helped.
At first the air con seemed OK but started not to get really cold. For the last 12 months it has worked OK if you are travelling along but when stationary or in slow traffic it has not worked at all.
In the last few weeks it doesn’t seem to ever blow cold or even cool air even when moving forward.
I am based in Hertfordshire. Does anyone know a good automotive air conditioning specialist in the area? Alternatively anyone had the same symptoms and found a cure?
Thank you.
Post #493143 21st Oct 2018 7:02pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
In the past I have used excellent agricultural engineers, most new tractor and harvesters have now got aircon and they did a really thorough job at sensible prices. Have a look around for a Massey Ferguson or JCB dealer. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #493158 21st Oct 2018 8:47pm
Sounds like you have a leak somewhere. They should do a full vacuum test on it though before re-gassing. There is nothing that can't be fixed with a hammer😜😜
Post #493161 21st Oct 2018 9:01pm
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Sounds like the common fault with the compressor pressure valve.
The compressors ruin constantly on these later models and there is an electrically operated valve fitted that controls the compressor. These stick and fail.
Have a look at this thread http://www.fullfatrr.com/forum/topic43778.html
They are a swine to change as you have to remove the compressor.
Post #493165 21st Oct 2018 9:27pm
mjdronfield
My money is on the above. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #493177 21st Oct 2018 10:14pm
kooky_guy
If there are no leaks then it does sound like he compressor control valve.
I've just had my whole compressor replaced as the bulk of the cost is removing it. It didn't seem worth just replacing the valve.
It was very expensive though. 2010 4.4 TDV8 Vogue SE
Post #493199 22nd Oct 2018 7:52am
Simes
I did the opposite - and just changed the valve - but, it's a good full day's work (or was for me).
Post #493207 22nd Oct 2018 8:46am
London Rangie
Thanks to everyone. I have now read the other thread. I think a replacement of the compressor and valve should do the trick.
Post #493768 27th Oct 2018 4:31pm
Simes
I think the new compressor will come with the valve already fitted.
Post #493794 27th Oct 2018 7:04pm
