Home > eBay & Bargain Spots > Aluminium jacking pads.
Page 2 of 3 <123>
GI JIM
United Kingdom 2004 Range Rover Vogue 4.4 V8 Buckingham Blue
Going to pick up 2 sprinter jacks on sat from a breakers £40, he says he has lots???? Whistle
I am also going to manufacture the aluminium pads as I have access to these types of CNC machines. If all works out and it is cheap and easy enough I may make some spares if all goes well. I will put up some pics of end results in a couple of weeks. May The FFoRRce Be With You
Post #492773 18th Oct 2018 12:42pm
kooky_guy
You'd be onto a winner if you combined the two...!
I'd buy one! 2010 4.4 TDV8 Vogue SE
Post #492778 18th Oct 2018 12:59pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
GI Jim, I'd be interested in a set please Very Happy Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #492786 18th Oct 2018 2:40pm
GI JIM
The part that Baltic Blue found on fleabay is back on again at 7.99 + 3.99pp don't think I could get the material for that Big Cry so maybe that is the cheapest way to it. If anyone has purchased this part is there a hole on the bottom for the jack head as I am still awaiting a response from the seller. It may be cheaper and less work if I buy this and retro fit it to the jack Question May The FFoRRce Be With You
Post #492903 19th Oct 2018 12:05pm
Baltic Blue
No they do not come pre-drilled., but are very easy to modify if you have access to a pillar drill and a 16mm bit.
Post #492904 19th Oct 2018 12:12pm
Bushy30
I suspect it would be GI Jim, still be interested in one if you have the jack and the aluminium block, I had considered getting the ally block in multiples and doing a group buy -- I already do reversing bulbs as a group buy Smile Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #492905 19th Oct 2018 12:19pm
kooky_guy
Me too! I've already got the ally pad but no jack and not really set up for that sort of drilling. 2010 4.4 TDV8 Vogue SE
Post #492910 19th Oct 2018 12:59pm
GGDR
I'll take one if we do a group buy.
. Cheers, Greg
Post #492912 19th Oct 2018 1:17pm
Emperor Mong
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Loire Blue
Interested in a finished product - not set up to do it myself.
Post #492915 19th Oct 2018 2:51pm
Baltic Blue
Are the jacking points the same on a L405 ?
I thought I had read that the BMW size jacking point was only on the L322., but not certain.
Post #492917 19th Oct 2018 2:57pm
Hairy Dan
United Kingdom 2014 Range Rover Vogue SE SDV8 Luxor
I also wondered about the L405 jacking points although looking at the user manual it looks like they may be different.
 Cheers Ian
Kielder 4x4 Safari
Post #492927 19th Oct 2018 4:19pm
GI JIM
Got the first 2 Jacks today. A bit of a shambles at the breaking yard but boss not in so I need to speak with him about exact numbers of Jacks he has.
Hope this picture works as this is the first one I have tried to upload Big Cry May The FFoRRce Be With You
Post #493037 20th Oct 2018 6:01pm
Baltic Blue
Take care when you remove the horns off the top to NOT let the piston fall.
Post #493039 20th Oct 2018 6:11pm
GI JIM
Cheers for that I most certainly will now Thumbs Up Drilling the pad is no problem as I have a CNC machining centre and a CNC lathe to do all that bit easily. The L405 would need a block with a V groove or slot which is ok as long as we get exact sizes. If anyone can get another source for new jacks then a group buy would be good once we get it all in place Very Happy May The FFoRRce Be With You
Post #493041 20th Oct 2018 6:39pm
Baltic Blue
Post #493050 20th Oct 2018 7:36pm
Page 2 of 3 <123>
