Home > Technical (L322) > Catastrophic brake failure! |
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 |
Wow, nasty! How did you know which brake pipe had gone? |
20th Oct 2018 5:13pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Both front to rear pipes run down the passenger side
20th Oct 2018 5:25pm |
SidewaysMatt Member Since: 24 Feb 2016 Location: Ledsham, Cheshire Posts: 173 |
The soaking of brake fluid under the passenger side sill and trail of fluid along the road gave it away!
20th Oct 2018 5:54pm |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
Surely it should have dual circuit brakes like other cars and vans, usually paired diagonally opposite front left, rear right and vice versa? It sounds more serious than a brake pipe failed, it would have to be two pipes failed or something else. BMW i3 Electric Car
20th Oct 2018 7:00pm |
No dual circuit brakes.... .
20th Oct 2018 7:34pm |
Really? I thought that was a legal requirement under the construction and use regulations. My flabber is well and truly gasted. BMW i3 Electric Car
20th Oct 2018 7:58pm |
Don't know but all I can say is not enough braking force to hold it back from the creep of the auto transmission. 2004 Vogue TD6 - Remapped
20th Oct 2018 10:57pm |
I assumed the same that the brakes would be dual circuit and work to some extent. But no. Never had brake failure before, had classic cars where you get the precursory weep, but this was very sudden 2004 Vogue TD6 - Remapped
20th Oct 2018 11:06pm |
Before anyone wades in I am going to qualify my remark. The FFRR does have dual circuit brakes, but does not have two(dual) brake lines running to each corner. The split reservoir system in the master cylinder is supposed to provide limited braking effort in the event of a fluid leak.
21st Oct 2018 12:28am |
Thats what I was meaning, dual circuit brakes are normally split front left and rear right paired, front right and rear left. A broken line will drop fluid from one circuit but not the other hence my comment that even though one line had failed, the pedal shouldn't hit the floor and there should still be a reasonable amount of braking. BMW i3 Electric Car
21st Oct 2018 3:14am |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1755 |
Providing the rest of the braking system is serviceable |
21st Oct 2018 7:28am |
Full Fattie Member Since: 10 Aug 2018 Location: Sunderland Posts: 245 |
If the pedal hit the floor then you likely have some other damage. If the fluid is down that side then it could be that the fault is causing the fluid to run along the outside of the pipe |
21st Oct 2018 7:44am |
It is also possible as prompted by mikey that only half the system had been working before! BMW i3 Electric Car
21st Oct 2018 8:39am |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1353 |
Its happened to me, and yes the pedal plummets to the floor. I wouldn't overly worry about other bits being broken at the moment. It even says that in the linked image that pedal travel and brake effectiveness will be affected.
21st Oct 2018 8:38pm |
