![]() | Home > Technical (L322) > Door card removal |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3218 ![]() ![]() ![]() |
Shouldn’t be - can’t see any change on mine from when I changed my 2004 dvrs door card. |
funnyguy1 Member Since: 11 Mar 2010 Location: Sun Valley, Idaho Posts: 390 ![]() ![]() |
Thank you! Can the door handle cable installed without unhooking all the electronic cables?? |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
Removed for a glass replacement, this photo gives an idea of the passenger door on a right hand drive car, I assume the driver's door on a left hand drive is similar.
Not sure but I think the cable can be accessed without removing the cables, but that is not too difficult. Hope this helps Cheers Richard (there are no such things as an ordinary FullFat, an ordinary cat or too many tools) 2011 TDV8 Vogue Santorini Black Gap IIDBT Last edited by rjff on 17th Oct 2018 3:49pm. Edited 1 time in total |
Not really a good idea as you need to support the door card then. It also puts strain on what are pretty flimsy cables which could snap. Just take a photo of the wires in situ and then replace. |
I'll clarify:
Thank you all!! Great info. I also ordered new door panel
fg1
Knightmare Member Since: 22 Jun 2015 Location: Kent Posts: 84 ![]() ![]() ![]() |
I've just done the same thing on the driver's side to replace a blown speaker. The great British weather then decided to release a monsoon just as I got the door card off. Fiddly is an understatement when you're outside, can't shut the door and only have one pair of hands.
Sir Knight
Thanks for the tips.
Good luck and look forward to hearing it's fixed |
Yay, all sorted...well kind of. What a difference a dry sunny day makes!
Hi RJFF,
