Home > Maintenance & Mods (L322) > Towbar Electrics
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
Towbar Electrics
Managed to get a genune Westfalia towbar from the bay of E, complete with electrics. Unfortunately, the electrics are 12N only (black trailer socket), so I am going to need to get a new loom for the 13 pin connections on the caravan. My question is, is the electronics module the same for all 3 available electric set ups (Land rover list 3, 12N only (trailer connector), 12n + 12S (older caravans with the 2 plugs), and 13 pin for the more modern caravans). The electronics module I have is marked as follows:-
AHM II 12V
BMW 61.35-6 955 253
SIEMENS VDO
5WK10250B
HW02 SW01
A140503
If the same module is used for the 13 pin wiring loom, I can just buy the new loom, and use the existing module with it, selling the 7 pin loom on the bay of E. If the module is different, then I will need to get a new loom and module, and sell the whole 7 pin set, loom and module, on the Bay of E.
Vehicle is a 56 reg 4.4 V8 Vogue.
Grateful for any advice Confused
Post #243744 20th Feb 2014 4:06am
IIRC as long as its the correct module for your vehicle thats all that matters.
The electrics that plug in are the only thing that differ though plugging them in requires stripping one or two plastic panels from the boot floor to do it right Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #243822 20th Feb 2014 1:06pm
T24RES
Don't forget you'll need the extra relay and wiring for the caravan fridge/charging system.http://www.westfalia-automotive.de/fileadm...391101.pdf Ian
Post #243868 20th Feb 2014 5:44pm
module is the same for all of the wiring options. Thumbs Up
this is mine on a 13 pin setup.
the lower numbers differ but the main bmw part no is the same Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #243899 20th Feb 2014 7:14pm
Full Fat Ray
Thanks for the help guys Very Happy Thumbs Up 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #243946 20th Feb 2014 10:31pm
Full Fat Ray
Another question - forgive my ignorance but I am still learning about my FF. Embarassed
Apparently, I have the Jag AJV8 4.4L engine, with the six speed box. Will the BMW module still work, or will it be different? I am assuming that as towing electrics are not engine related, Land Rover would have just continued using the BMW module? Question 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #244594 23rd Feb 2014 10:54pm
If you have touch screen nav then you simply need the 05-09 module Thumbs Up
Post #244595 23rd Feb 2014 11:02pm
DrRob
I need to do the same on mine (2011 4.4). It currently has a single black socket but want to convert to 13pin.
Does anyone know if its a simple case of replacing with a new loom (will go OEM) and retain the existing module?
I have access to an IID Pro if it needs anything changing in the settings.
TIA
Rob Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #492406 15th Oct 2018 11:48am
On a 2011 you only need to order the loom sir... There is NO module on 09> Rob
The plug is against the rear panel at the rear of the spare wheel hole👍
Post #492408 15th Oct 2018 12:07pm
DrRob
Cheers Craig Thumbs Up
https://www.advancedfactors.co.uk/ba4019-t...2470-p.asp
https://www.paddockspares.com/ywj500460-ki...trics.html
Correct?
Bow down Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #492423 15th Oct 2018 3:25pm
Andy
PF Jones sell the wiring looms
Post #492478 15th Oct 2018 10:40pm
DrRob
This one looks right for me Thumbs Up
https://www.pfjones.co.uk/land-rover-range...clone.html
There is a cheaper PF Jones one.....any experiences anyone?
https://www.pfjones.co.uk/land-rover-range...506pf.html Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #492533 16th Oct 2018 1:18pm
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Some have had a good experience with PF Jones. I, and lots of others, didn't.
Check trusted trader reviews.
Post #492549 16th Oct 2018 2:28pm
DrRob
Genuine 13 pin on its way from Dan at Duckworths Thumbs Up
Only fitting so I can charge battery with the Ctek and adaptor from forum store Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #506929 1st Mar 2019 8:31pm
Nick591
Forum store? Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8
Post #507016 2nd Mar 2019 4:20pm
