![]() | Home > Maintenance & Mods (L322) > Towbar Electrics |
IIRC as long as its the correct module for your vehicle thats all that matters.
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
Don't forget you'll need the extra relay and wiring for the caravan fridge/charging system.http://www.westfalia-automotive.de/fileadm...391101.pdf Ian |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8702 ![]() ![]() ![]() |
module is the same for all of the wiring options. |
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 ![]() ![]() ![]() |
Thanks for the help guys |
Another question - forgive my ignorance but I am still learning about my FF. |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
If you have touch screen nav then you simply need the 05-09 module |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4326 ![]() ![]() ![]() |
I need to do the same on mine (2011 4.4). It currently has a single black socket but want to convert to 13pin.
On a 2011 you only need to order the loom sir... There is NO module on 09> Rob
Cheers Craig |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
PF Jones sell the wiring looms |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
Some have had a good experience with PF Jones. I, and lots of others, didn't.
Genuine 13 pin on its way from Dan at Duckworths ![]() Only fitting so I can charge battery with the Ctek and adaptor from forum store ![]() 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
Nick591 Member Since: 04 May 2017 Location: Seaton Dalaval Posts: 193 ![]() ![]() |
Forum store? Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
