![]() | Home > Maintenance & Mods (L322) > Turbo drain mod |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2566 ![]() ![]() ![]() |
The revised turbo drain was not factory-fitted to any L322 nor to early L405s. The TSB shows the affected VIN ranges. |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 ![]() ![]() ![]() |
Have you got a copy of the TSB please Graeme? Current: 2011 FFRR Vogue SE 4.4 TDV8
barrieeld Member Since: 07 Dec 2010 Location: Scotland Posts: 260 ![]() |
Yes that would be great!
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
the tsb is in the wiki...
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
And again, drive it properly, and you won’t have an issue......slog round at 1500rpm and on the occasional slip road bootfull you will get a cloud of smoke....
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 814 ![]() ![]() |
Agree with that
just to add that there are suspicions that not having he mod done will somehow affect the dpf but its not certain this is true.. |
A friend of mine bought a low milage 405 4.4TDV8... The first time we drove went for a bit of a run out, over the bridge to wales and about an hour into our journey, all hell brakes loose from the exhaust!!!
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Mine hasn't had the mod done (yet), I was concerned about the DPF and actually monitored the soot load when I knew I was going to cause plenty of blue smoke. It didn't make any difference, gave it full throttle and sure enough quite a cloud to start with but cleared after 30 to 40 seconds and the soot load was unchanged. In my mind the particles in the blue smoke will be too fine for the DPF to hang onto and therefore pass straight through.
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 502 ![]() ![]() ![]() |
just to add my experiences which differ in opinion to what many consider on here.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
Mines not had the mod done. I dont get chance to put my foot down much so earlier this year it smoked quite a bit on start up and moving away....then was ok.
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1661 ![]() ![]() ![]() |
Quite agree with the over 2500 once per trip - sounds like a plan from now on. Like NMJ says the second turbo is there and it should be used as designed.
Once mine has cleared the oil out 30 to 40 seconds I have to do 20 or 30 miles of below 2500 driving before it build up enough to make a noticeable amount of smoke. BMW i3 Electric Car
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Adrian and others,
