Home > Maintenance & Mods (L322) > 4.4 TDV8 Belt tensioner replacement |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
Great write up, nicely done thanks. May I ask the approximate cost of the tensioner and do you have the part number?
13th Oct 2018 12:23pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8501 |
Tensioner was £112 from Dan (duckworthparts)
13th Oct 2018 12:28pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35262 |
i've taken the liberty to wiki'fy this Mark.. |
13th Oct 2018 12:33pm |
JWL Member Since: 07 Aug 2016 Location: North Wales Posts: 42 |
Great write up - thanks.
27th Nov 2018 10:38pm |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1185 |
Good, write up many thanks on my to-do list. |
28th Nov 2018 8:31am |
the belt is not easy to do with just the tensioner off, the fan would need to come off and the fan shroud too I reckon.
28th Nov 2018 6:50pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4300 |
Is this tensioner usually the cause of a squeak when cold? No squeak when warm Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
3rd Dec 2018 9:17am |
Mine is doing exactly that, the belt is running about 5 mm off the edge of the tensioner, I have bought a new one and fitting it or having it fitted shortly. BMW i3 Electric Car
3rd Dec 2018 4:48pm |
probably.
3rd Dec 2018 7:43pm |
Put a tensioner on my Xmas list Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
4th Dec 2018 1:00pm |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
Great write up, could i humbly suggest adding part numbers to aid the slower members ( me ) 2015 4.4 AB
4th Dec 2018 8:36pm |
its on there a couple of posts down
4th Dec 2018 10:19pm |
Thank you and a classic example of a slower member ( me ) 2015 4.4 AB
4th Dec 2018 11:20pm |
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 145 |
I checked the tensioner pully today but then saw something worrying.The crankshaft pully seems to run with a wobble Surely this pully must run true?There is no noise and everything is running quiet.Has anybody noticed this?If the front bolt is lose will it not be noisy?The front part of the pully drives the fan and the rear part the rest.The long belt runs smooth with very little movement on the tensioner pully.
21st Jan 2019 7:59pm |
