Home > Technical (L322) > New message on dash
New message on dash
New message for me today......
Bong - gearbox overhearing.
Flappy paddles not working
Not towing when it happened
60000 miles 4.4tdv8.
Just had potatoes up the M42 from brum to derby in traffic at 60.
Got home fine, didn’t seem to affect it too much driving wise, went out for a couple more runs but the message didn’t re appear. Can’t think what could actually cause the box to overheat in those circumstances..... so am thinking bogus message?
Anyone had this/or any ideas?? There is nothing that can't be fixed with a hammer😜😜
Post #492017 12th Oct 2018 8:25pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Was the torque converter locked up?
Possibly a bad connection on temp sensor?
Fault codes ? BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #492018 12th Oct 2018 8:40pm
Baltic Blue
I don’t think I have ever read any posts re gearbox problems.
Presumably you have checked for any error codes on iid ?
Post #492020 12th Oct 2018 8:45pm
Baltic Blue
No.6 is the transmission fluid cooler, I think a quick check to look for anything blocking air flow ? Wet leaves , poly bag sucked up?etc.
Post #492022 12th Oct 2018 8:56pm
Yep, will have a look at that in the AM Mike.
Not sure if the converter was locked up or not. Do we know if there is a thermostat in the system?
Edit.... seen that now looking at the pipework on microcat it comes as part of the pipe.... There is nothing that can't be fixed with a hammer😜😜
Post #492024 12th Oct 2018 9:29pm
m@ttsFF
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Can you decode the ‘just had potatoes up the m42’ ?
Does that mean bimbling along all the way , or driving like you stole it until Brum when you slowed due to traffic?
Or something completely different? 🧐 4.2 SC - sold , now bought back
4.4 AdBlu Tractor - Stolen
Post #492031 12th Oct 2018 9:54pm
GGDR
I read another post recently saying they got a gearbox overheat message..
Will have a hunt for that..
. Cheers, Greg
Post #492032 12th Oct 2018 9:55pm
is this any help?
http://www.fullfatrr.com/forum/post368388.html
Post #492036 12th Oct 2018 10:05pm
Don’t have an IId so plugged in my el cheapo diagnostic and got no codes, but i don’t know if it reads the gearbox module.
Pootle ——- potatoes (auto correct) Big Cry
Stan - Thought I remembered something. It’s due a box oil and filter change so I will order some fluid and a trans filter from Dan. There is nothing that can't be fixed with a hammer😜😜
Post #492037 12th Oct 2018 10:18pm
potatoes sounds better ..i had a carrot up to the NEC yesterday Mr. Green
Post #492048 13th Oct 2018 7:51am
GGDR
Laughing Laughing Laughing
which leads nicely to the classic "Banana in the tailpipe" from Beverley Hills Cop
. Cheers, Greg
Post #492050 13th Oct 2018 8:00am
Weegie
stan wrote:
potatoes sounds better ..i had a carrot up to the NECK yesterday Mr. Green
That must have been painful Shocked John
GAP iiD BT-Sold
Post #492067 13th Oct 2018 9:49am
Grand Designs Stan ? There is nothing that can't be fixed with a hammer😜😜
Post #492075 13th Oct 2018 11:16am
Just tracking down a filter..
Have gone through the ZF site and it come up as a 1087.298.364
Lr Part no is LR065238
Is there anyway to double check between the 2 that they are one and the same ?
I can get the ZF one for about £65.00..... delivered There is nothing that can't be fixed with a hammer😜😜
Post #492090 13th Oct 2018 12:24pm
Baltic Blue
Try sending Nino a PM.
I am sure he has said in the past that he had got one .
He may even have posted pictures.
Post #492092 13th Oct 2018 12:41pm
