Home > Maintenance & Mods (L322) > Sunroof seal
Renegade2
Sunroof seal
if you look at the sunroof when it is closed there is a rubber seal that goes around, mine has lifted slighly in the middle at the rear, i have tried to press it back in but it is not having it and it seems to have stretched. Does anyone know if this is a replacable item? it has started whisting at speed and is annoying now.
Post #103819 27th Jan 2012 12:44am
longmanh
United Kingdom 2011 Range Rover Autobiography TDV8 Baltic Blue
Slightly old thread but thought I'd see if you'd managed to sort this as mine has the same feature? 2011 Baltic Blue FFRR 4.4TDV8 AB
Post #491980 12th Oct 2018 4:03pm
Balloonengineer
As far as I know the seal is not available separately
The seal join is at the middle rear, they have a strip of metal fingers inside to grip the glass and it rusts then swells.
I have a spare sunroof with a seal which I am happy to take off as it has a bit of damage of about 25mm at the front, but for the cost of a bit of postage someone can have it (or a bit of it!) if they want a bit of spare section to splice in a damaged bit!
Best wishes
Glen Previously......
Series 1 80, Series 3 88, Turbo 90, 300tdi 90, 110's with 200, 300, TD5
TD5 Disco, Disco 3, 200Tdi Disco - probably the best vehicle Landrover ever made,
Now 3x FFRR, some would say I should have learned by now......
Post #492027 12th Oct 2018 9:38pm
longmanh
Hi that would be great, thanks.
Drop me a PM with a postage cost and I'll send some details over.
Thanks Glen. 2011 Baltic Blue FFRR 4.4TDV8 AB
Post #492610 16th Oct 2018 10:12pm
