Home > Maintenance & Mods (L322) > Resetting suspension heights after front strut replacement
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
I replaced the front nearside strut with a new complete unit (shock absorber and airbag etc) but have since noticed a deviation in height between sides, around 2cm both front and back.
Is there a method to equalise the heights without using an iid tool? I've tried lowering and raising through the various heights but the deviation is still there Crying or Very sad
Thanks
Post #491599 9th Oct 2018 3:54pm
there is a method..its detailed in the GAP manual ..[link in wiki]
Post #491600 9th Oct 2018 4:32pm
The air spring wears as does the shocker over time/miles so, Should really change them as a pair sir...
Post #491611 9th Oct 2018 5:51pm
JCW
I considered replacing both but the other side had already been changed upon checking the date sticker.
Stan, I cant find anything in the Gap manual, could you direct me to the right section please?
Post #491619 9th Oct 2018 6:55pm
GraemeS
The height isn't affected by changing the strut as the height sensor is untouched in the process.
Post #491629 9th Oct 2018 7:33pm
Sure it wasn't there before ???
You will need an LR compatible diagnostic tool to adjust height settings .
Post #491633 9th Oct 2018 7:46pm
JCW, page 47 in the GAP manual...
Post #491639 9th Oct 2018 8:01pm
@ stan Question Question Question
Post #491653 9th Oct 2018 10:15pm
m@ttsFF
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
On my iPad p47 relates to section 3.5.5 (plus 1page)
 4.2 SC - sold , now bought back
4.4 AdBlu Tractor - Stolen
Post #491655 9th Oct 2018 10:28pm
JCW
Thanks all, so only possible to calibrate with an iid tool or similar (annoyingly I had one but inadvertently left it in my last RR when I sold it but the buyer refused to return it...).
Its possible the heights were out before changing the strut but sure I'd have noticed, I'll check the height sensors in case I managed to dislodge or damage something.
Post #491662 10th Oct 2018 6:15am
