![]() | Home > Technical (L322) > New to me L322 2012 AB - Questions questions |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7860 ![]() ![]() ![]() |
Welcome.
DSLiverpool Member Since: 30 Sep 2018 Location: birkenhead Posts: 9 ![]() ![]() ![]() |
Ah thanks for that, rear seats are sorted, locking wheel key sited in boot with diesel reset key (both in glovebox), rear hearing is a button to press every time I start up I guess (why?)
There is a recent discussion about the rear ventilation button here
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
Whip the tailgate trim off to refit the boot/switch cover.
matthews Member Since: 09 Aug 2016 Location: Leeds Posts: 100 ![]() ![]() ![]() |
Drive away autolock can be turned off in settings with column buttons , some people like it personally I don't . |
srpara Member Since: 03 Oct 2013 Location: moray Posts: 115 ![]() ![]() ![]() |
You can get the strap that pulls the tyre up from Dan at Duckworth (site sponsor) they are cheap to buy new, also get the two bolts for it at the sametime as are not part of the kit.
Your lower glovebox has a piece you need to pinch to release the glovebox to the floor to expose the fuse board... The part you pinch has either broken off or, quite commonly it remains in the pinched position... If this is what has happened to yours? Wedge a bit of foam/rubber in behind it and that should make the catch work once again... |
