![]() | Home > Maintenance & Mods (L322) > Front end conversion |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35476 ![]() ![]() |
nickj and dan have had front ends done , put 'conversion' into the search and there's loads of info.. ... - .- -.
There is no reason for the lights to throw up faults. I wouldn't let an auto electrician near the car unless he has specifically worked on the L322 before and has done the conversion.
darrenmax Member Since: 20 Apr 2010 Location: antwerp Posts: 420 ![]() ![]() ![]() |
i did mine in a weekend, no problems really, the problems with the lights are if you do a 2010 conversion not a 2006 2002 td6 vogue, 06 supercharged facelift
am i correct in saying that a td6 doesn't need a cone [k&n] air filter when converted.. ... - .- -.
no cone filter needed on a td6, but the pipe from the inner wing to airbox is a tight fit 2002 td6 vogue, 06 supercharged facelift
Nickj Member Since: 13 Aug 2010 Location: Ipswich Posts: 262 ![]() ![]() |
Not sure of the conversion you refer too, but if its a 2010 coversion, do it yourself. Most of its easy!! Wiring- just follow l322.com guide and i managed the front as a novice( regard wiring).
I've had a k&n style filter and no issues.
hongkongphooey Member Since: 26 Aug 2010 Location: Douglas. Posts: 227 ![]() ![]() |
Wouldn't mind having a chat about it if you'd be kind enough ![]() I'll PM over my number, maybe give me a call when it's convenient? Cheers. |
PM'd back |
