Home > General > Microcat Query
GJOB
2005 Range Rover Vogue SE Td6 Java Black
Microcat Query
Hi All,
I've finally got around to installing Microcat but I don't seem to be able to get it to run properly even after following the instructions...
I'm getting an "out of date" message and changing my PC date has no effect, can anyine shed any light why its not working??
Im running Windows 7 btw if that helps.
Thanks
S
Post #49107 6th Feb 2011 5:31pm
dan_uk_1984
Can I just check you are definately clicking apply and OK when you change the date/time? It's caught me out a couple of times Smile
D
Post #49109 6th Feb 2011 5:37pm
GJOB
D
Hi Dan, Yes definitely Mr. Green I know it changed because I forgot to change it back and some sites certificates would load due to the date anomoly(sp?)
Post #49130 6th Feb 2011 7:17pm
GJOB
I'm going to try and install it again, do i need to change the date before installation or doesn't that matter.
Is it as simple as per the readme file or am I missing something?
Post #49290 7th Feb 2011 7:54pm
