Home > Maintenance & Mods (L322) > Reverse light units
Full Fattie
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
Reverse light units
Yesterday while I was washing the car the cap off one of my reverse lights fell off when I was drying it. It’s not damaged as it came off in my hand so didn’t drop on the floor. The part that screws to the lower tailgate is still there and also seems fine.
I assumed it would clip back on and it kind of dies but it doesn’t seem very secure. I’ve conpared it to the other side unit and that is still attached but also doesn’t seem very secure. Are these just clipped on or should there be something to bond them on?
Also, while looking at replacements I noticed some being listed as 2002-2009 while others show the full model years of 2002-2012. Did the units change on the later L322 cars? If so, what was the change as I’m struggling to see anything online.
Thanks in advance
Post #491015 5th Oct 2018 1:10am
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
A plastic tag at the bottom of the unit hooks inside the lower tailgate, then a plastic pin locates in a hole in the tailgate, then screw at the top, all secure, wobbles very slightly, but no real movement.
They certainly can't 'fall off' if they have all the right plastic bits and are screwed in properly. Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #491030 5th Oct 2018 6:44am
Full Fattie
I don’t think I’ve explained clearly but the part that houses the bulb and has the screw through it is still attached to the tailgate. It’s the lens that has fallen off.
Post #491138 5th Oct 2018 8:01pm
glue it back on with silicon glue...
Post #491140 5th Oct 2018 8:20pm
Bushy30
Stan, as ever, spot on! Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #491142 5th Oct 2018 8:33pm
Full Fattie
I did think about that but thought it was a little crude. The bulb is replaced via the rear of the unit so glue does make sense.
Post #491154 6th Oct 2018 12:49am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
I have just refitted both lenses on mine. With the lamps off I gave them a good clean and run a very light bead of clear silicone around the mating surface before refixing both halves. Very easy 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #491267 7th Oct 2018 2:07am
Full Fattie
Thanks, I’ve removed both, cleaned them inside and out then siliconed around the edge lightly. All seems good now
Post #491621 9th Oct 2018 6:57pm
