Home > Maintenance & Mods (L322) > Reverse light units |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 |
A plastic tag at the bottom of the unit hooks inside the lower tailgate, then a plastic pin locates in a hole in the tailgate, then screw at the top, all secure, wobbles very slightly, but no real movement.
5th Oct 2018 6:44am |
Full Fattie Member Since: 10 Aug 2018 Location: Sunderland Posts: 245 |
I don’t think I’ve explained clearly but the part that houses the bulb and has the screw through it is still attached to the tailgate. It’s the lens that has fallen off. |
5th Oct 2018 8:01pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35368 |
glue it back on with silicon glue... |
5th Oct 2018 8:20pm |
Stan, as ever, spot on! Current: 2011 FFRR Vogue SE 4.4 TDV8
5th Oct 2018 8:33pm |
I did think about that but thought it was a little crude. The bulb is replaced via the rear of the unit so glue does make sense. |
6th Oct 2018 12:49am |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 |
I have just refitted both lenses on mine. With the lamps off I gave them a good clean and run a very light bead of clear silicone around the mating surface before refixing both halves. Very easy 2007 TDV8 VSE
7th Oct 2018 2:07am |
Thanks, I’ve removed both, cleaned them inside and out then siliconed around the edge lightly. All seems good now |
9th Oct 2018 6:57pm |
