Home > Technical (L322) > Dropped suspension on my l322 |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
Could it have been this way before your suspension work. If you have an IID tool you can reset the heights to the correct level. 2015 4.4 AB
1st Oct 2018 6:39pm |
m@ttsFF Member Since: 12 Dec 2017 Location: Surrey Posts: 327 |
The joints should be tightened when the weight is on the wheels - could this be it? 4.2 SC - sold , now bought back
1st Oct 2018 6:42pm |
duplicate 4.2 SC - sold , now bought back
petebowling Member Since: 17 Jul 2018 Location: Thetford Posts: 20 |
I didn't do it that way weight was off, can it be jacked up without wheels on to put weight pushing upwards or do I need to have the wheels on? |
1st Oct 2018 6:54pm |
The levels were ok before the work, I have a Hawkeyes can they be reset from this |
1st Oct 2018 6:58pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
You will need to loosen off the front suspension nuts/bolts for the wishbones, get weight of car on the wheels at "normal height", then tighten up the bolts. Only then should you try calibration.
1st Oct 2018 9:04pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Simply ask the garage doing the alignment if (maybe for a small fee) if you can put the car on the alignment ramp and loosen/re-tighten the wishbone bolts... That way you can do all the tightening with the wheels on the floor albeit on a ramp... |
1st Oct 2018 9:33pm |
What's a iiD tool? is that like a LR Hawkeye diagnostics tool |
17th Oct 2018 8:34am |
https://www.gap-diagnostic.com/products/iidtool/ .
17th Oct 2018 11:23am |
