Home > Maintenance & Mods (L322) > Auto box 'Flush' techniques?
GGDR
Dropping the oil from the drain will get 3, 4, or at best 5 litres out of the the auto box.
My ZF8HP70 takes 8.5 litres so that leaves a lot of old fluid still in the cooler pipework and the TC.
"Flushing' using a pump seems to be the professional method, but wondering any way to change 'most' of the fluid if you don't have a pump.
I asked a mechanic recently he said he would do a drain and fill, test drive it a bit, then repeat same day to ensure full fluid change.
Interested to know any thoughts or suggestions.
. Cheers, Greg
Post #490338 29th Sep 2018 5:18pm
m@ttsFF
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
I drained and refilled mine 4 times to be sure I got out as much old fluid as possible on my 6hp
Not the most efficient method , but worked for me and easy enough to do at home - also changed the sump and mechatronic sleeve..
I toyed with removing the oil cooler lines at the box and flushing that way , but settled with the drain and refill
Use a garden spray pump to get the oil back in and iid tool for checkin* the temp 4.2 SC - sold , now bought back
4.4 AdBlu Tractor - Stolen
Post #490340 29th Sep 2018 6:05pm
bruno22rf
England 2004 Range Rover Vogue 4.4 V8 Java Black
My local independent offers a "power flush"- is that not an option?
Post #490367 29th Sep 2018 8:06pm
GGDR
Looking for techniques I can do myself....
. Cheers, Greg
Post #490369 29th Sep 2018 8:14pm
kooky_guy
Isn't the fluid hideously expensive? I would have thought that would preclude repeated fluid changes.
I just had my fluid drained and filter replaced. That was expensive enough! 2010 4.4 TDV8 Vogue SE
Post #490497 1st Oct 2018 7:25am
@ £10 a litre, @ 5 litres per change so for 4 changes @ £200 to get most of it swapped over. Not hideous... Thumbs Up .
Post #490504 1st Oct 2018 8:46am
DrRob
I got a quote of around £300 to megaflush including supply of the 8 speed oil. No filter change. Just a complete change of oil. LR charge more for the oil than direct from an oil supplier to correct spec Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #490508 1st Oct 2018 10:12am
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
There are a couple of threads on the Disco forum that might be of interest:
FILO's autobox oil change (6 speed)
Robbie's Guide To ZF8 Auto Transmission Oil Change 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #490514 1st Oct 2018 10:48am
