Home > Maintenance & Mods (L322) > engine rattle/timing chain?
moby2004
United Kingdom 2004 Range Rover HSE 4.4 V8 Bonatti Grey
Hi everybody, need some advice
how much does it cost roughly for timing chain/guide/tensioners etc replacement as my baby has started to rattle at top/front of engine
Post #489469 21st Sep 2018 12:46pm
b348xyx
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
if that is the issue its expensive i would rule out everything else first.
Your looking for everything needed replaced, around 3k as its around 18-25 hours labour depending who does it.
If you need vanos units replaced at same time or rebuild you can add that on top. the seals start to fail and can created noise and performance loss.
http://www.fullfatrr.com/forum/post423718.html#423718
Quote:
"Would recommend http://www.lrsengineering.co.uk/
For the timing chains and guides rebuild so on.
Did my engine rebuild and they have done quite a few of these.
prices very good and very good keeping you updated so on."
 2003 Range Rover 4.4 Litre V8 - Adriatic blue
2003 Range Rover 4.4 Litre V8 -Maintenance History Click Here = http://www.fullfatrr.com/forum/topic39687.html
Post #489473 21st Sep 2018 3:11pm
Dolphinboy
I paid £3000 at a specialist LR indie. That’s new chains guides etc. Front had to co me off but if they tell u the enginr has to come out tell them to get stuffed. It doesn’t (but takes more time and expense!)
Post #489655 23rd Sep 2018 10:25am
just on a vanos point, I recently used Mr vanos to do a swap for a refurbed unit on my e36 M3. was £800 and that included him coming out to me and stripping the top end in my garage and putting a new "fixed" unit in.
Nice chap Steve, if a little busy and difficult to track down. There is nothing the chap doesn't know about BMW engines, more the performance ones I reckon but might be worth an ask.
www.mrvanos.com
He's up around Darlington but will travel. There is nothing that can't be fixed with a hammer😜😜
Post #489657 23rd Sep 2018 10:33am
moby2004
I am going to attempt this myself as cannot afford garage prices have sourced parts recquired but which manual do I need to guide me thru ?
Post #490445 30th Sep 2018 6:26pm
Dolphinboy
Check out Holidaychicken's posts on here. He's done it and left some good pointers.
Post #490473 30th Sep 2018 9:04pm
