![]() | Home > Maintenance & Mods (L322) > Rear lower wishbone help |
Keep up the good work |
Doesn't make any difference if you refit the wishbones, they are not really in the way, and it gives you somewhere to support the hub. might be best just to loose fit for that purpose without the air bag, then do things properly once the subframe bushes are done? Don't know....
deltic Member Since: 18 Jun 2018 Location: dublin Posts: 57 ![]() ![]() ![]() |
Well JOE 90 took exhaust off from manifold handy, dropped sub/frame all bits disconnected, , got a plate and steel tube made up its a must, got the 2 rear bushes out had to cut the lip off the top of the old bushes sorta handy, replaced both not so handy but no damage to equipment have the w/ bones suited and booted all ready to go back after i de/rust where i can while all bits are out happy enough so far the sub/frames are a lot easier and quicker than the w/bones to do, will fit all back when paint dries hope its as handy thanks to JOE 90s WIKI |
Got the bits back on to day, only problem was one of the sub/frame bolts was tight on the last few turns had to put a thick washer in to take up the slack, wheels on tomorrow and hope the air bags dont act up.
All done no problems, even had time to give it a wash to keep it happy thanks everyone for there help cheers |
